Portable no backlit, video fades away
Aektann
Could you please help me to determine a problem with my original no backlit Macintosh Portable? It starts ok and displays a mouse, beginning to boot normally, but then the picture fades away. My machine was fully recaped and working well before this day. What should I check first?
imactheknife
Good battery? Also have to recap power adapter. I just recapped my adapter yesterday.
GRudolf94
I've never seen a panel fail like that. I'd check that you have 5V and contrast voltages at the display after the failure occurs. Smells like latent cap damage.
Aektann
I've figured out the reason. The ribbon cable connection the display panel and motherboard seemed to be broken a bit. Hopefully, I'll try to restore it.
