Performa 450 restore / no chime
c00gr
Hey folks… picked up a Performa 450 at an estate sale and the board was a bit grungy with leaky caps, but otherwise in decent cosmetic condition. PSU voltage looks good, fan spins, HD spins up, but then no chime, and then the HD idles. Recapped the board as well, checked traces around the caps and things seem ok except for the negative side of C13 where a soldered in a jumper to the back of the board. I recorded a video of where I’m at currently, but not sure where to go from here… open to any ideas you might have!
Here’s the video:
joshc
Apologies I haven’t watched the video but what voltages is the power supply outputting?
joshc
Potentially a bad Egret chip. Have you got any photos of your board so I can see if I can spot anything?
c00gr
Here are some photos of the board… I’ve been checking traces on the EGRET chip and so far things seem continuous, but I still need to trace a few more pins…
Was it the LC III that has the incorrect silkscreen on one of the caps? Like, the -12 supply cap silkscreen was backwards?
c00gr
Also reflowed the EGRET chip and still nothing. Also checked voltage on pin 4 of U22 and it’s 4.9V…
c00gr
I wonder if the ROM chips are bad… Any ideas on how to check them? I have an EPROM reader so I guess I could try to see what’s there?
c00gr
Also I checked voltage on U7 Pin 15 and it was 0.1… is that expected? Confused a bit about the refresh circuit…
joshc
I can see some top layer corrosion on the PCB near the DFAC/Sound Chip, around some of the vias there:
The DFAC is part of the Reset circuit, definitely worth checking continuity of everything around there and check if those vias are compromised.
