I'm pretty sure it's just a plain old Microsoft Bus Mouse. However, the Bus Mouse is mostly forgotten now days.
It may be. It does have an Outbound label. But logic would say is just a regular mouse I suppose.
The port on the side of the machine is not a VGA port. If you attach a VGA monitor to it you will likely kill one of the diodes in the power supply. I had one like that once which I had to repair. Got the diode specification from Perfit back in the early 90s. I was not the person who connected the monitor, BTW. Since you have the manuals, you probably didn't need the warning, but it is such an enticing mistake to make.
I've learned over the years to assume nothing when it comes to ports and hardware. I did read that damage can happen. The port is similar to the Mac Portable port. Digital out so to speak. Meant for an LCD maybe.
Did you, perhaps, check with the seller to see if there was a Plus or SE that he obtained along with it? It sure would be nice to find an example of that docking card. Even if all I get to see is pictures from you. The cable for the docking card should be the same as the cable for the SCSI adapter, which is the same as the cable the external floppy uses.
While I have the cable, there is no dock card. But the seller is seeing if there is a floppy drive, power supply and now a computer that may have be the Outbounds other half. Seller is not the original collector of these items, so he is checking with the person he got this from.
SCSI target mode will work fine without the docking card. The two are not associated. BTW, the internal hard drive is an IDE device, strangely enough, which I think makes it the first Macintosh or clone to use an IDE drive.
Okay, that is REALLY cool to know! I knew the drive was IDE, but the target mode I figured exclusive to the card. Now I know I can make a backup of the 40MB drive! Thanks!
If you install an OS on the silicon drive, you can then install new OSs on the hard drive by connecting the laptop to another Mac via LocalTalk, and then booting from the Silicon Drive. Risky though. If something goes wrong and you lose the silicon drive while the hard drive is unbootable, the machine is hosed unless you can get access to a floppy drive.
Good info, but this drive will be left
as is for now. I like the idea of keeping this one as Don had it. There is a LOT of stuff on here. While I am sure its just a small portion of his work, other items like the software are very interesting! I don't think it really adds value to the machine as much as it adds to the story!
Welcome to the ranks of the Outbound Model 125 Laptop owners. They are a very cool example of technology from 1990.
Thanks! The more I read the more amazed I am by this tech. It has some really neat features only seen on later models. I like it! Think its a keeper!
