Thanks for the info about problematic caps. I've got a Duo 280c that needs inspection for this problem. The full Dock had the clicking problem a long time ago, but I never replaced the PSU caps. I did not think it was an operation I could handle myself. More recently, I recapped the PSU in my TiVo DVR, and that was rather easy. The Powerbook disassembly is a bit more intimidating, but I can handle it if I can find a clean surface to work on.
Can someone tell me if these issues are symptoms of the bad caps? The Duo runs fine when the battery is inserted and the power supply is connected, but the battery is not recognized. I used to be able to trick the Duo into seeing and charging the battery if I removed it for a few seconds and then reinserting it. That doesn't work anymore. If I remove the battery, the Duo will turn off after a few seconds. The Duo will not turn on unless both the PS and battery are connected. Resetting the Power Manager does not help.
Also on the capacitor agenda is a couple of my Quadra 840av motherboards. Hopefully they haven't damaged the MB yet.
