robin-fo
@mathieutozer More likely, this is due to the lack of AppleTalk support.
Currently, my preferred way to run Netatalk on a Mac is inside a Linux VM. Install UTM and a prepare lightweight Ubuntu Server setup. Then compile and install Netatalk. My preferred way to do this is using the PiSCSI installer.
atalkd
is only used for AppleTalk and AFP over DSI/TCP should work without it. I don‘t know how this docker image works, but disabling AppleTalk support in Netatalk is probably the way to go.Currently, my preferred way to run Netatalk on a Mac is inside a Linux VM. Install UTM and a prepare lightweight Ubuntu Server setup. Then compile and install Netatalk. My preferred way to do this is using the PiSCSI installer.
