Netatalk 2.2.8 Released
CTB
I just tried the full install process again to use a bigger SD card. I got the following errors.
Make sure you have the required Berkeley DB libraries AND headers installed.
You can download the latest version from http://www.sleepycat.com. If you have installed BDB in a non standard location use the --with-bdb=/path/to/bdb configure option and make sure your linker is configured to check for libraries there.
configure: error: Berkeley DB library required but not found!
apple@retroPi:~/netatalk-2.2.8 $ make all
make: *** No rule to make target 'all'. Stop.
slipperygrey
Are you sure you have installed all of the dependencies? This error usually indicates just that: The Berkeley DB dev package hasn't been installed.
I created a wiki page recently for documenting the required packages for various OSes. Please look under the Debian section: https://github.com/Netatalk/netatalk/wiki/Installation-Notes#debian-linux
CTB
Ah, the latest build on the Raspberry Pi site still needed an update (apt-get update). I didn't expect that.
c..
paws
For some reason I'd always thought setting this up was difficult, but it turned out to be no trouble at all. I now have AFP access to my NAS and little web server. Though the UTF-8 Markdown format I normally put online is a little unwieldy on OS 9, maybe I should get into Dreamweaver or finally learn (Mac)Perl. But that's for another thread. Thanks for this software and this thread!
slipperygrey
You're very welcome! I'm glad to hear that it worked out well for your setup.
Admiral Ackbar
Failure to get AppleTalk support built into kernel, using latest Raspbian image download. Following https://github.com/PiSCSI/piscsi/wiki/AFP-File-Sharing.
Getting to this step:
make -j4 Image.gz modules dtbs
Shows the below. What did I miss? Using Raspberry Pi 4 Model B Rev 1.2 hardware. Intent to use netatalk 2.2.10
warning: ld does not support --fix-cortex-a53-843419; kernel may be susceptible to erratum
warning: LSE atomics not supported by binutils
./arch/arm64/include/asm/atomic_ll_sc.h: In function ‘__ll_sc__cmpxchg_double’:
./arch/arm64/include/asm/atomic_ll_sc.h:318:38: error: ‘__uint128_t’ undeclared (first use in this function); did you mean ‘__int128__’?
318 | : "=&r" (tmp), "=&r" (ret), "+Q" (*(__uint128_t *)ptr) \
./arch/arm64/include/asm/atomic_ll_sc.h:325:1: note: in expansion of macro ‘__CMPXCHG_DBL’
325 | __CMPXCHG_DBL( , , , )
./arch/arm64/include/asm/atomic_ll_sc.h:318:38: note: each undeclared identifier is reported only once for each function it appears in
./arch/arm64/include/asm/atomic_ll_sc.h:318:51: error: expected expression before ‘)’ token
./arch/arm64/include/asm/atomic_ll_sc.h: In function ‘__ll_sc__cmpxchg_double_mb’:
./arch/arm64/include/asm/atomic_ll_sc.h:326:1: note: in expansion of macro ‘__CMPXCHG_DBL’
326 | __CMPXCHG_DBL(_mb, dmb ish, l, "memory")
make[1]: *** [scripts/Makefile.build:118: kernel/bounds.s] Error 1
make: *** [Makefile:1289: prepare0] Error 2
make: *** Waiting for unfinished jobs....
slipperygrey
@Admiral Ackbar Unless you're using a very early Raspbian Buster, or previous releases, you shouldn't have to modify the kernel to get appletalk. If the module isn't loaded when you run lsmod, try starting atalkd which should dynamically load the model if it isn't already.
Admiral Ackbar
Thanks. I don't understand what could have been wrong, and since I was working from a Raspbian image from a few weeks ago, I just tossed it and tried https://www.macip.net/ so I could get the module bits integrated already in the image. Now I need to see if it is indeed 2.x of netatalk and how I can get it over UDP so it will work with AirTalk devices I bought.
slipperygrey
I removed the section on compiling the Linux kernel from my wiki page. It's not relevant right now. It was only early on in the lifecycle of Debian Buster around 3 years ago when appletalk had suffered a critical bug and you had to build the kernel yourself.
