Johnnya101
Was putting together my newly recapped 140 with reinforced plastic hinge posts... Yeah. Snapped again.
Im very close to just drilling holes into the darn thing and using bolts or something.
How the heck to you fix this? Does someone have a very clear set of instructions or description? I used JB Weld but its was soft after curing for a month... Anything easier or better? Or should I just use bolts?
