NEC Multispin 3xe CD Drive Trouble
LC_575
I recently acquired a nice external SCSI drive - an NEC Multispin 3xe cassette-loading CD drive. My problem is that no Mac I have will mount any disc in the drive.
Now I'm 100% sure the drive works. Insert an audio cd (actually I was using a CD-R) and it plays fine. Once it's connected via SCSI, the Mac successfully detects it and there are no ID conflicts. The problem comes with mounting the cd in the drive.
Both of my SCSI capable macs (LC 575 and Performa 6300CD) exhibit this same problem. It leads me to believe that the NEC drive requires some special driver software to work. Would anyone know of it?
Scott Baret
What sort of driver software are you using? Third party drives often need their own device drivers.
I used to have a 3X NEC, and it worked fine with FWB CD-ROM Toolkit 2.0. If you can purchase a copy of that, you'll likely be in luck with the NEC and for that matter any non-Apple CD-ROM. Otherwise, you'll need NEC's software.
Those old NEC drives are great, I always regret getting rid of mine. Not sure what yours is like, but I could use mine as a standalone CD player as long as there were speakers hooked up to it.
Scott Baret
The Apple CD driver definitely doesn't work with the NEC drive. CD-ROM Toolkit (2.0 or greater) or the NEC driver are your only options here.
LC_575
Found FWB Cd Toolkit 4.0.1b on Cnet, and just my luck, I get a 404 error when downloading.
My search continues...
LC_575
Before I head over to Ebay, might anyone have a copy of FWB Cd rom toolkit and be kind enough to send me a disk image or .sit?
protocol7
