Olympiaman1010
I just got a LCIII a few weeks back. I have my 100mb SCSI zip drive hooked and working perfectly. Since I got it, I thought it had a PRAM issue because I would have to turn it off and turn it back on several times. I got a new 3.5v 1/2AA for it and it seems the battery was not the issue. I next thought to zap the PRAM but to no avail.
Basically what happens is, in the mornings when I turn it on I have to listen and wait. When the hard drive spools down, turn it off and then back on, sometimes more than ten times. I hear both the system fan and the hard drive spool up. The hard drive makes two attempts to read the system files and disk shuts down leaving only the fan running. After several more tries I finally hear the tick, tick, tick I have been waiting for. To test it was the hard drive not the system, I put the system folder on a zip disk. When it doesn't want to boot from the hard drive and gives me the question mark I pushed the zip disk in. It booted perfect with only the sound of the system fan and the somewhat quiet loading of the zip disk.
Does anyone else have a moody hard drive that boots only when it wants to? I am fairly new to the 68K realm but have been working with computers since our family's first IBM 5150. I used Norton tools to check the disk as well and everything checks out OK. Once the computer is on and running the disk works perfectly and never gives me any trouble. It is truly amazing to be reunited with a machine that I spent hours on at friends houses. I also have a Mac 512k upgraded to a plus that is at my parents house that I would like to get going, I know it works perfect and is maxxed out. It even has the laser mouse! Now that I have a SCSI Zip drive it should make things easier. I never could do anything with the 800k floppys but with the external SCSI zip all those problems are solved. The only downside to the whole operation is having to use Tiger 10.4 to put everything on to zip disks because 10.6 decided to quit writing HFS files. At least I am still able to use zips and floppys as a read only so I can get the nostalgia of using the LCIII for word processing.
If anyone could help me with this hard drive hiccup that would be awesome. I would like to hear any feedback or thoughts on what I should do next. Or, if I should just deal with the trials and errors in the morning and forget the whole thing. Once the hard drive has been on for a while it restarts just fine and gives me no trouble, like I said, its only when it has been sitting off for the night. Thanks guys
-James
-James
