BadGoldEagle
Hi there,
Thanks to Bibilit, I am now the proud owner of an SE with two floppy drives. It works great, but I think it would be even better if it was equipped with a SCSI2SD.
Because of the two FDDs, conventional HDs won't fit properly. See Vectronics' pic of their HD-equipped M5010.
But what about an Apple bracket + SCSI2SD ?
Unfortunately, I don't have a spare HD/Empty bracket on hand to try. Do you know if it fits?
I started working on a bespoke M5010 SCSI2SD bracket. But perhaps this work is useless...
