markyb86
So the 60mm fan in the SE is making a lot of noise, like its off center or needs an oil job or something.
When it comes to repairing computers, Usually I'll use what I have lying around first before trying to pay money.
First I was going to just make a bracket from plexiglass (And I did, but drilling holes in it FUBAR'd it. :'( :'( :'( I even dremel'd out an apple for a fan grill.. what luck having brittle plexi.)
What I came up with next was cut apart an ATX PSU, for the sheet metal AND fan.
All I did was snip off the old fan (left enough wire on fan in case I change my mind), and soldered this guy on.
It fits pretty snug in there, maybe 1-2mm away from the video board. I put electrical tape on the side of the bracket in case vibration makes them touch. I don't want a grounding issue.
I also had to remove the fan shroud from the back case.
Well, it did quiet down the noise I was hearing. Now to do something about the 20MB HDD.. whirr whirr whirr.. ugh. )
Next project is to see about some retrobrite materials, while I wait for this USB>Serial dongle.
