egrath
Hi,
my Macintosh II seems to be dead in the water, power supply isn't starting up, even when using the jumpstart method of supplying 5 V between the white pin and ground. So my assumption is that the PSU itself has some issues. Are there any known issues with the Astec AAI3780 power supply which i could check? In a first inspection i didn't saw any obvious issues (fuse is OK, no leaked or cracked caps). Any hints on how to start the analysis?
