Macintosh 16-inch Color Display -- Post Recap Issues
ktkm
A couple of weeks ago, I decided to fix minor convergence issues with my Macintosh 16-inch Color Display. Hence, after finding a burnt capacitor on the main board, I thought it was time to have the entire display recapped before I began fiddling with all the potentiometer dials. I started with the video board, which was pretty easy and then moved over to the main board, which was slightly more time-consuming, to say the least. However, when all the old capacitors had been removed except for a few (the big 470 µF 400 V and a couple of bi-polar cans), I noticed that “KEY geometry” had started to wobble ever so negligibly. Focus, convergence, and geometry have improved, but I’m not too fond of the wobble. To illustrate the issue, I made this exaggerated animation.
Has anyone here ever had this issue with a CRT and knows what causes it? Or perhaps have had a successful recap of a Macintosh 16-inch Color Dispaly?
3lectr1cPPC
I have a problem just like that on my Blueberry iMac Slot-Loader. I assumed it’s caps going bad as well. I’d also like to know what else besides them could cause it if you’ve got the same issue after a nearly complete recap.
ktkm
Problem solved! It was my own human error!
I took the whole thing apart and noticed I had put one capacitor, “C302 (10µF 50V),” on backwards. It didn’t show from the top of the board, but things became clear when I flipped it over. That particular capacitor sits next to the KEY trim-pot. This is what you get when you start soldering at 02:00 a.m.
After my recent endeavour, I would start looking at components close to the KEY trim-pot area. However, I’m not sure what that would look like on Slot-Loader iMac.
Another thing: I found was a button magnet held by some double-sided tape on the back of the CRT.
Is that common practice for Trinitron tubes of this size?
3lectr1cPPC
Good to see you got it figured out. I’m really putting off recapping mine as it’s a massive pain to get the analog boards out, and I’m likely to destroy the display bezel trying. I’ll bet it caps though.
