jmacz
Well the thing is, the two capacitors aren't making a difference for me. Whether the 2.2uF or 0.1uF or both are connected doesn't change the outcome. What does change the outcome is that 470 ohm resistor across REQ and TERMPWR. Without that resistor, it almost rarely works. With that resistor it seems to currently always work. Right now I have just the resistor connected and the capacitors removed and everything is still good. If I disconnect that resistor, stops working again.
The PSU is a recapped Sony. No other PDS cards currently installed. Vanilla board with the one ZuluSCSI and that's it. It's ranging between 4.9V to 4.95V so I think that's close enough? I can check later if there's a pot to bring up the voltage but I think that's probably close enough?
