gsteemso
Hi all,
It seems to me that (beyond the stuff common to all vintage machines like leaky electrolytic caps) there are three common points of failure in old PowerBooks -- batteries, 2.5" SCSI drives and shatter-prone case plastics. I've seen options, if occasionally pricey ones, to deal with the first two, but I've never seen anyone step up with a solution for the third.
I know it would not be straightforward to replicate _every_ replacement case part for each of the many, many different PowerBooks that were made, but you'd think some of the more common ones would be doable... at least the parts that almost everyone sees fail, like the stuff around the hinges, for example. I recall when my 2300c's screen frame plastics died, back in '99 or thereabouts, the repair guy said there were several PB models in his boneyard that could contribute the needed bezel... except the ones he had were all brittle and disintegrating as well. It seems somewhat incredible to me that in the 15 years this problem has been rendering otherwise good PowerBooks useless, no one has ever tried to fab a more durable replacement. (I've some experience with fabrication houses, and if I had the CAD skills to draw up proper designs, I'd run a kickstarter campaign to do exactly that, but I just don't have the expertise to follow through.)
My sister is a certified machinist, and what little I picked up during her training tells me that exactly reproducing a complex shape like that would probably be horrifically expensive, whether made directly of metal or by milling a mould and pouring new (stronger) plastic. That said, it seems to me that the really complex fins and stuff around things like binding posts would be largely superfluous if you made the replacement out of a more sturdy material, like metal or modern high-strength plastics... especially if you weren't too bothered about making it as light as possible, like they had to be back in the day. Honestly, at the weight those old beasts mostly were, adding another pound or three is hardly going to be noticeable unless you are very young, very old, or very ill.
Can anyone comment on the feasibility of this idea, or some modification thereof? I can't really ask my sister, as she lives in another country and has essentially zero knowledge of this specific problem domain (computer case design).
