Got it working
@jessenator! Note the anode (red hole coming out of CRT) is on the opposite side relative to Mac CRTs. You can tell because the neckboard connectors on the amber monitor are 180* off - the missing pin should be on the top left if you're looking at it from the back. Other than that its a drop-in replacement and easy to swap the yoke and get it running.
Instructions, largely cribbed from
techknight's video posted earlier:
- Remove amber CRT from existing monitor electronics
- Remove neckboard and yoke from your Mac's CRT (unscrew yoke and wiggle and wait for crack sound)
- Add amber CRT with missing pin at top left, anode at right (when facing from behind)
- Add neckboard and yoke, and rotate yoke ever so slightly right (see photo IMG_4340). Screw down partially but enough wiggle room.
- Set Mac up & turn on
- Adjust yoke rotation until its straight, be careful
- Adjust CRT settings on analog board (height, brightness, focus) with plastic CRT tools
- (if needed) Adjust yoke magnets
Another useful resource I found is
this video on discharging the CRT, though I haven't done this myself.
You can see in my images the picture is warped which means the yoke magnets now need adjusting. I'll do that next, but I think I need to find some video guidance on that and want to be extra careful.
When I first added the yoke the picture was rotated clockwise too much. I rotated the yoke clockwise to here, which has the top pink magnet adjustment at about 12 o'clock which straightened the picture.
This was how it looked on first plug-in.
And after yoke rotation, where you see its rotated correctly but the top center is warped (magnet adjustment too weak there?). The picture is slightly up and to the left of center, I don't know how to solve that yet.
