I have a Macintosh IIfx with a Macintosh High-Resolution Video Card (supports 640x480 at 67Hz) and when running it through a 10-switch DB15 to VGA adapter set up in 13" RGB mode, I get green video. And by green I mean...really green.
I'm using one of these adapters set for 13" RGB, mode 5, which is the only setting I've found that successfully outputs video.
What could be causing the green tint? I'm wondering if maybe I need to set the adapter for Sync on Green instead...
