M0401 AppleColor High-Res RGB monitor capacitor list?
JC8080
Does anyone have a capacitor list for the M0401 AppleColor High-Resolution RGB monitor? I found a thread with a list for the later M1297 revision, but I was not able to find anything for the M0401.
danny.gonzalez.0861@gmai
I am currently going over my monitor and have the PSU and D - Board listed. Please note that this is not 100% verified but is to my best knowledge is accurate. I should be getting the first batch of capacitors in a few days.
D - Board
Capacitor LocationCapacitance ValueVoltage RatingDia. (mm)Height (mm)Lead Spacing (mm)Notes
C5471uf160v8mm14mm2.5mm
C524470uf35v10mm20mm5mm
C569100uf25v* 35v8mm10mm2.5mmUPGD to 35v
C529100uf35v8mm10mm2.5mm
C570100uf25v* 35v8mm10mm2.5mmUPGD to 35v
C591100uf25v* 35v8mm10mm2.5mmUPGD to 35v
C572100uf16v6mm10mm2mm
C546100uf16v6mm10mm2mm
C592100uf16v6mm10mm2mm
C5942.2uf50v5mm10mm2mm
C5952.2uf50v5mm10mm2mm
C5172.2uf50v5mm10mm2mm
C5994.7uf50v5mm10mm2mm
C5934.7uf50v5mm10mm2mm
C5884.7uf50v5mm10mm2mm
C5164.7uf50v5mm10mm2mm
C5264.7uf50v5mm10mm2mm
C597.47uf50v5mm10mm2mm
C5201uf50v5mm10mm2mm
C5231uf50v5mm10mm2mm
C5011uf50v5mm10mm2mm
C5051uf50v5mm10mm2mm
C5061uf50v5mm10mm2mm
C5101uf50v5mm10mm2mm
C53010uf50v5mm10mm2mm
C58410uf50v5mm10mm2mm
C531470uf16v10mm13mm5mm
C51922uf25v5mm10mm2mmUPGD to 50v
C5113.3uf50v5mm10mm2mm
C5133.3uf16v5mm10mm2mmUPGD to 50v
C58647uf16v5mm10mm2mm
C58747uf16v5mm10mm2mm
C568470uf35v10mm20mm5mm
C58122uf250v12mm23mm5mm
C57533uf160v15mm25mm6mm
C5124.7uf (BP)50v6mm10mm2mmBi-Polar Cap
PSU:
C107470uf400v35mm40mm10mm( - | ) Leads
C1084.7uf350v11mm25mm6mm
C1094.7uf350v11mm25mm6mm
C11322uf25v5mm10mm2mmUPGD to 50v
C21522uf25v5mm10mm2mmUPGD to 50v
C20947uf25v5mm10mm2mmUPGD to 50v
C21047uf25v5mm10mm2mmUPGD to 50v
C2164.7uf100v5mm10mm2mm
C203100uf160v16mm26mm7mm
C20533uf160v12mm20mm5mm
C20622uf100v8mm10mm3mm
C204470uf100v11mm30mm7mm
C218100uf25v6mm10mm2mmUPGD to 35v
C219100uf25v6mm10mm2mmUPGD to 35v
Hope this helps!
Daniel G.
JC8080
Great, this is very helpful, please update if you find any errors in your list. Are you recapping any of the other boards?
Why are you recapping? Preemptively, or to try to fix an issue? Mine works fine but is a bit dimmer than I think it should be, but it's been so many years since I used one of these I really don't remember how bright they should be.
I am glad it was helpful.
I will let you know the progress and if I find and issues.
I was having, what I can describe only as contrast issues that, when the monitor was warm, would fix itself. Figured that was a perfect indication of failing capacitors. I could use my EGR to determine which are good or bad but I figure for the $40 in capacitors, it's a great investment in the monitors future.
Hope all is well!
JC8080
That cap looks a bit rough. I heard recently, maybe from Adrian's Digital Basement, that a bulging appearance is normal for those large caps with the plastic bit covering the top of the cap, and it is not necessarily a sign of leakage. That one is bulging quite significantly though, it would definitely concern me. When I have recapped IIsi PSUs I have always replaced the large caps even though people say it is not necessary. I figure as long as I'm in there, and already ordering parts, I may as well do it for peace of mind.
Well, everything on the list was indeed accurate. I can share what I bought from Mouser with the exception of the filter cap. Although it was the correct size and value, the lead spacing was off by just enough that I drank an entire beer until I was able to figure that one out 😉 but in the end it did indeed work out flawlessly.
I found a few cracked potentiometers so my geometry is off until I care enough to take it apart and/or find the values online.
Also, note that I didn't recap the rear AV board as I didn't see a reason to. Maybe someone can add that last part for the world.
A lot of the caps I removed were Rudycon caps which aren't bad but they were 85c rated and I changed them to 105c high life rating so hopefully the next person to do this will be after I'm dead.
I will post the Mouser list the moment I get home.
Thanks!
Hello everyone,
Sorry for the late response with the Mouser list. Got a horrible cold and am still going through it.
In any case, here is the PDF you can use to order the parts from Mouser or cross them to your preferred vendor.
Hope this helps!
  • M0401 Mouser List.pdf
