jmacz
Finally found a DB15 cable (with all the pins) to test an M1297 AppleColor High Resolution Monitor with my Quadra 700. Everything looks good and the monitor seems to work.. but I've got this really strange distortion in the left corner.. it's like the top 3-5 rows of pixels are shifted to the left. It's not across the entire screen but maybe 40% of the width? But it's only the top 3-5 rows of pixels. I thought it might be the geometry (pin cushion distortion) but the rest of the left side of the screen is perfectly vertical and no issues in the bottom left corner either from what I can tell. Anyone have any idea what the issue might be?
Here's a picture:
You can see it on the File menu where it's black. The upper left corner has a tail because of it. Same when you click on the other menus including the Apple menu. But the menus on the right side of the screen are normal and not shifted.
Any ideas?
Here's a picture:
Any ideas?
