l008com
Is this a thing? I know it's a thing with hard drives. Both the physical adapter to fit a 2.5" drive in a 3.5" bay, and also the adapter to convert laptop IDE to desktop IDE. But optical drives are much less standard than hard drives. But it would be very cool if you could get a physical adapter that would let you install a laptop optical drive in a 5.25" optical bay, and line up the slot with where it would go on the desktop, so the slot loading disk would spit right out of the hole in an old Mac where the disk tray would otherwise be. And then you'd also need some way to convert the odd connection laptop optical drives have into standard IDE connections.
I love the idea of having a classic mac that is silent, none of that super loud disk noise.
