Scott Baret
Monitor has interference when cursor is moved or new text appears. This comes in the form of horizontal lines that are light gray against white. It's not an ADB issue due to modifier keys not causing this problem.This usually only happens or can be noticed on blank white screen.The monitor seems fine otherwise.I'm guessing potentially the boards/caps, potentially the fact it's on a circuit at an apartment building when many people have A/Cs running. Never have had this issue until recently.
I do have a spare board with new caps to swap in if need be, but I'd like to rule out anything else first--specifically the CRT itself.Thoughts?
I'm hoping it's just something on the boards since I do know an analog board swap has fixed similar issues on compact Macs.
