Introducing (and interest check) AirTalk: Wireless plug-and-play LocalTalk dongles
Hi all,
has anyone used the device on a mac plus? If yes, how do you power it? Can we steal some power from e.g. floppy drive connector?
@cheesestraws do you believe it would be ok to solder a wire on the usb +5v terminal and feed it to the floppy drive connector? Would it be already grounded or would in need an additional wire for ground?
Many thanks,
Andrew
Cheesey included a USB Micro port to power it using a USB charger, it doesn't specifically need ADB, that was just for convenience.
The easiest option would be to power it with USB. It's safe to have the USB and the serial plugged in at the same time: that's what it's for :) . If you want to power it from the machine, you should be fine to get 5V from the floppy port I think. (I can't remember how much power is actually available from that port but if it can run a floppy drive with a motor in it ought to be fine for this).
Ground—I would give it its own ground pin, mostly because if the box is wired up to a computer through a localtalk box, that box is an isolation transformer. If you're modifying the device to have an extra 5V input, you might as well add the extra GND at the same time and save yourself trouble later if you want to pop it on the far side of a localtalk box.
I'd actually suggest adding the wires to one of the ADB ports rather than the USB port: they're functionally identical, and the soldering job will be much easier because the connections are rather larger.
piernov
New member
Hi, just for fun I made CopperTalk (blue PCB), "AirTalk on Ethernet". Sadly firmware is in a pretty bad shape, file transfers are extremely slow, so it's not ready to use yet, maybe one day I'll be able to figure out what the problem is, or if ever someone wants to look at it… firmware is mostly the AirTalk firmware ported to Zephyr. Hardware is an STM32F107 MCU.
Also made my own spin of the AirTalk board (black PCB) just for fun as well.
Oh, this is great stuff. Is your AirTalk PCB working reliably / did you have enough information to do it relatively straightforwardly? Reproducibility is great :D.
Do you know where the slowness in CopperTalk is creeping in? There was a weird issue I never really tracked down with some older AirTalk firmware where there was obviously a timing issue of some description that made things get wedged in a state where there was a big delay in it responding to LLAP frames. Some fix along the line got rid of it, and I never totally worked it out...
piernov
New member
The AirTalk board is inspired from the schematics you posted a while ago (not sure about the license of that though). It's mostly the same, I mainly added a CH330N for programming and debugging the ESP32 from USB. I redrew it in Kicad and designed the PCB there as well. It runs your FreeRTOS-based AirTalk firmware. Of course I made a few mistakes but that's how it goes, otherwise it seems like it's working as expected between a PowerBook 170 and Mini vMac.
I started porting the AirTalk firmware to Zephyr using the AirTalk board and IIRC it had the same issue I have now with the CopperTalk board. So it shouldn't be related to the MCU or the Ethernet but more likely a threading/queuing problem I guess. Sadly I don't have a great understanding of the inner workings of the firmware (and the LocalTalk protocol and communication with TashTalk) so I'm not sure where to look for the problem.
I put the firmware here for now: https://github.com/piernov/coppertalk_firmware
CopperTalk firmware is on the master branch, AirTalk Zephyr firmware is on the airtalk branch.
(in fact it's been a while since I worked on that and it's a bit of a mess but eh)
Yeah I really should do something about clarifying the licensing situation. How about this: the AirTalk hardware is under the CERN-OHL-S-2.0. I haven't uploaded my gerbers and stuff, but that's out of inertia rather than anything else. If anyone wants them please let me know and that'll give me the impetus to do something about it. If that license is incompatible with what anyone wants to do with it, please contact me. I am not a license absolutist :)
Good call. Not adding USB for this to mine was, in retrospect, a mistake. Programming and debugging would have been significantly more ergonomic if I had!
I'm pretty sure that the issues I was seeing was that, but as I said, they "organically" went away before I found out what they were. Sigh.
I'm very happy to answer any questions you have about the AirTalk firmware, and I can tell you my understanding of talking to the TashTalk though I'm not an expert in its innards. @tashtari 's own thread about the TashTalk is here: https://68kmla.org/bb/index.php?threads/tashtalk-single-chip-localtalk-interface.38955/ and might be a good place to ask!
Code is always a bit of a mess. I shall find it interesting having a look at your code. Thankyou!
micheledipaola
Hi all,
Many thanks,
Andrew
I am moving files between my Plus and my SE/30 this moment, using two AirTalk boxes.
What I did is using the second ADB port of the AirTalk connected to the SE/30 to plug another ADB cable towards the AirTalk connected to the Plus, thus providing power there too.
All hail @cheesestraws for these little devices!
jazzius
I am interested in getting this to use with my Macintosh SE for quickly copying files over from my modern PC! I recently got an internal BlueSCSI for it, but I have no convenient way of moving files to it and ZIP disks seem to be flaky and clunky at absolute best. How can I get one of these? What is the asking price?
FYI: Also, is this a kit? I CAN solder by the way and I actually soldered together my BlueSCSI kit myself to begin with.
daanvdl
Hi Jazzius,
I am working on a Airtalk kit and manuals, aiming at sub €50 for preprogrammed complete sets.
I will update within a few weeks. I need to do some more testing and finetuning before going live.
Cheers,
Daan
Iesca
Perhaps I missed it, but how does one setup Mini vMac 37's LocalTalk-to-UDP functionality?
Just going to link here to @daanvdl's new thread for the AirTalks they're building: https://68kmla.org/bb/index.php?thr...-and-play-localtalk-dongle.43838/#post-478876
Now that they've successfully built some and beta-tested the files for me, I'm officially making some noise that this is open hardware under the CERN-OHL-S-2.0. The hardware files are at https://github.com/cheesestraws/airtalk/tree/main/hardware but you might be well advised to wait for @daanvdl 's instructions, which are less perfunctory than mine. Go forth and build some! :)
stepleton
I hope it's not unkind to ask: have there been any developments in understanding 6100 incompatibility? Did it turn out that the 7100 and 8100 have similar problems, or are they immune?
Not unkind at all, I just wish I had a better answer for you: I still have no idea why it doesn't work with the 6100, and my 8100 gets more and more broken every time I try to fix the last thing that broke :-(.
I can test it on an 8100 and see if needed.
@cheesestraws - I don't think I mentioned, but my 6100 was the very first machine I tested it on and I couldn't get it to work, but assumed it was me. I moved into another room and used a powerbook instead and assumed it was just the WiFi was too weak at the 6100. Ages later I saw discussion that 6100s were trouble.
Sorry I didn't report it, I thought it was just me.
CTB
Yeah that'd be useful if you wouldn't mind, my 8100 is still out of action and getting more out of action all the time
Has anyone raised the possibility of the GeoPort being the problem? Wasn’t GeoPort first supported in the 6100/7100/8100? I know the serial ports were majorly revised for GeoPort support and backward compatibility.
It's possible, though if so it's a quirk restricted to those machines. The usual machine I use to test AirTalks before they go out is a PB3400, which has a GeoPort, and they also works fine with my TAM. Most oddly of all, they also work with both my 1400s, which is based AIUI on the NuBus PPC architecture. That's why I don't think it's a foregone conclusion that it won't work with the 7100/8100.
