LightBulbFun
So my 7410 chips arrived woo now that I have everything i hope to try and do the G4 CPU upgrade like you have done (as i said in a past post ill be trying first with a 300Mhz G3 ZIF) is there any last things I should know before i try? (im not using a bottom heater i plan to preheat the board with my hot air gun/re work station slowly.) any recommendations on what temp i should use when I put the G4 Chip on and are going to reflow it? I have a good idea but I always check with the experts first also i noticed my chips also i think have .76Mm balls they are defo smaller then whats on the G3 ZIFs chip for example. ill attach a picture and if you can tell me if they are like yours/ready to be soldered that would be very helpful
