asaggynoodle
I've done this about a dozen times, still trying to perfect this operation though (About ~40% success rate).
What temperature/equipment do you use to clean the pads after you remove the CPU? My boards almost ALWAYS lose a pad or two after cleaning them off with my Hakko and solder wick.
Also, what size balls do you use on your replacement chips? I've been using .76MM lead balls, but I feel they are too big. I can't find any way to get the suggested ones in the Datasheet.
