IIfx's Conquests
IIfx
Thought I might as well start cataloging all my conquests going forward in a single thread.
I bought a NewerTech MacClip Jr on eBay for the low sum of $4.99, new in box. It's for the Quadra 800 and 840av and advertises up to a 40% gain in performance. I will be putting that claim to the test!
Initial impressions are lukewarm. The clip does not sit securely on the clock generator chip. This lead to many oddities in my initial testing, all the way up to killing System 7.1.1 Pro. My specific Q800 is not stable at 40mhz, disk corruption issues arise both on the SCSI bus and off of the floppy controller. The clip had managed to wiggle off the clock chip while the system was on resulting in an "F-type" instruction fatal error followed by a vaporwave version of the happy mac, complete with garbage visuals on the screen. Hopefully no hardware damage occurred from this! I wouldn't think anything permanent would happen as modern components change their clock speed dynamically. The extent of the damage is probably just the corrupt copy of the system software that will need to be reinstalled.
Even if the clip turns out a total wash, it came with an oddball heat sink that does a surprisingly good job keeping the 68040 cool. It has a quiet small fan that moves a decent amount of air. It secures onto the CPU via a sled clamp. The heat sink is screwed onto the clamp, securing it against the CPU package. I did not use the included thermal sheet, instead opting for some Arctic Silver ceramic paste. Once I reinstall the OS the system will be tested at 38Mhz.
I attached a photo of the 68040 prior to cleaning. Still had the stock Apple paste from the factory.
IIfx
I bought an Apple Ethernet NB nubus card for $22 on eBay. It's one of the few cards that utilized the A/ROSE multiprocessing architecture. Apple claims it's dedicated CPU and OS results in increased host performance when performing networking tasks.
Thread dedicated to the card:
https://68kmla.org/forums/index.php?/topic/31419-apple-ethernet-nb-does-it-deliver/
Image album, including the box:
https://imgur.com/a/jorev
An update about the MacClip: it fried my Quadra 800's SCSI controller. These MacClips are dangerous due to their weak hold on the clock generator. Thankfully I had a spare bare logic board and transplanted the CPU, RAM, and VRAM to that.
IIfx
Bought a Mac Rominator II Mega from BMOW for my IIfx, along with the SIMM programmer. Booting from a ROM disk is lightning quick. I already customized the ROM with the Apple/Radius 24AC driver and some additional games and software.
On my list of long-term to do is to modify the startup chime. I want to cram in the PowerExpress boot chime, because my IIfx is loaded enough to be worthy of such a powerful chime.
