davidg5678
Hi all,
I am troubleshooting a Macintosh Classic that has severe battery damage (probably a lost cause, but I like a good challenge). The AB, PSU, and CRT are all tested and known good.
This machine displays horizontal stripes at power up, which I understand means the VRAM is not getting initialized. I've confirmed the CPU is receiving a good clock signal. It is not held in /RESET or /HALT. I also confirmed that the address/data lines are all pretty active in this machine. I've patched more dead traces than I can count, and verified proper continuity for every pin on the CPU, VIA, RTC, ROM, SOUND, and VR1.
I'm sure the culprit is going to be a broken trace leading to a rotten VIA connected to a bad IC. The trouble is figuring out which ones and where!
In an effort to troubleshoot this problem, I'd like to start pulling ICs from the PCB. Anything that isn't needed for the Classic to start up can go --I'm okay if this results in a "sad mac" for the time being, my goal is to resolve these horizontal stripes first. I suspect that several chips are probably damaged, and that one of them is probably bringing the whole system down (--if this theory is nonsense, please let me know...)
Does anyone here know which chips aren't needed? Can I get away without some of the capacitors as well? What sort of start up/initialization behavior should I be expecting?
I'd like to confirm the operation of the sound chip as well, but couldn't find documentation on how it is supposed to function. Any pointers?
Any and all advice will be greatly appreciated! Thanks!
