IIfx 16MB SIMMs -- Thanks Doug!
joethezombie
Cooked up some 16MB SIMMs for the IIfx today based on Doug Brown's design!  Worked perfectly!  Thanks so much Doug!  You're a legend!  Needs more exalamation!!!
luckybob
neat!  I wonder if I can contract him to make some 1mb 30-pin simms for some IBM machines I have that use unobtanium ram.
joethezombie
I ordered my boards through seeedstudio, because I had a pretty good coupon from a previous project.  But ALLPCB will send you 20 boards for $56 which is still a bit cheaper than what I spent for mine.  As far as chips, I spent $34.99 for a pair of 64MB modules on eBay, which had enough chips to make 9 completed SIMMs.  All in all, a bit shy of $7 per SIMM.  Not too shabby!  I have two IIfxs to populate, and will need a couple more 64MB modules to complete the set, which will leave me with 2 spare SIMMs and 2 bare boards in case of a failure.  So far, I've only built up the 4 shown, but they pass all memory tests I've tried.
I do feel bad for pillaging the chips from working modules.  If I were to make a lot of these, I would certainly try to find a supplier of bare chips.
joethezombie
Yeah, nothing in stock unfortunately.  There is a seller on ebay with a whole reel of bare chips, but is listed as "away" for quite some time, and they never responded to inquiry.  There is also the somewhat seedy asian distribution market, but with the few amount I was building, I didn't bother.
luckybob
I kinda assumed, if you were skilled enough to harvest memory chips from one simm for another, and do it where it looks nice, you probably already knew what mouser was.
TimHD
Great work! I'd be interested in getting 8 simms if you do end up making a production run of these. I'm sure here must be some others on here after those SIMMS and have no way of producing their own!
Juror22
I have access to some of these chips, TI TMS416400DJ - would these work?  I checked out the spec sheets and the pins were almost the same between these and the ones listed as working:
M5M416100BJ
KM41C16000BK
There are some minor differences, but I'm not anywhere near fluent enough in reading these to tell if they are important minor differences.
By the way, those are some terrific boards - nice job!
dougg3
Awesome! I like the color you picked :)
Also, I have to give kudos to trag for his original research on IIfx RAM which you can find on this site in various threads. His info was very valuable as I was designing the PCB.
joethezombie
Indeed, trag's posts are what led me to your design so I have both of you to humbly thank!   You guys are awesome!
@Juror22, I don't think those would work.  They appear to be 4Mx4bit chips.  Maybe they would work with trag's alternate 2-chip design that used a couple of bidirectional switches?  Not sure.
@TimHD, I'm not planning on making anymore unless a bunch of raw chips happen to fall in my lap.  It takes time to find the modules at a reasonable price on eBay, and even more time to remove them, and I don't have a lot of that.
But there is a gentleman over on mac68k.info that has secured a bunch of chips and has even boards.  I'd been watching for him to make sets or even kits to sell, but after two years of waiting, and no response to private email, I figure it's not happening and made my own.
olePigeon
I have access to several surplus electronics stores.  I can give them a call.  What chips specifically am I looking for?
Bolle
Shouldn’t 16Mx4 work as well? You will only need two chips that way. I was thinking about getting a few 30-pinners done with chips from 64MB 72 pin SIMMs I don’t need anymore.
Those will also be low profile enough to fit well into SE/30s with only two chips.
Getting two 64MB SIMMs + having blank SIMMs manufactured cheaply will also cost less than buying 128MB worth of 30pin SIMMs from memorymasters and the like.
I might look into that. It was always tempting to max the RAM on my WGS95 }:)
nyef
It'd be nice if 16Mx4 did work, even if such chips still aren't available via Mouser. And https://68kmla.org/forums/index.php?/topic/21519-finally-a-iifx/?p=221669 mentions a prototype involving paired 16Mx4s, a pair of FET bus switches (identified as SN74CBT3244 or similar), and a "five-pin gate" (probably an SN74xx1G series two-input of some sort)... But that they're finicky.  Given the theory that the use of fewer chips is causing ringing on the address lines due to reduced load from the chips themselves, I was wondering if a set of fairly stiff pull-downs might help, but this is definitely beyond where I'd trust my intuition.
Hrm... 1Mx16 is available. That can be run as 2Mx8, since it has separate "upper" and "lower" CAS pins. Still 8 chips, plus glue, but if it can be made to work then sourcing components becomes straightforward.
