Big Bird
I'm in the process of setting up a Mac IIcx as a LocalTalk Bridge/IP Gateway, but it has a really strange problem. It will retain a time that you set in the Date & Time control panel, but no matter what you do, it will not KEEP time. That is, once you "set" the time, it doesn't count seconds up. The same time just stays there. Unlike the symptoms of a dead PRAM battery, the IIcx retains the exact time that you set it to, down to the second, and does not reset the time or date to 1904/1956/whenever. Could it still be a PRAM battery that's keeping it from counting time?
It has a fresh install of System 7.5.5 on a known good hard drive, RAM, video card, and network card. MODE32 is installed. There's nothing in the machine I can figure out that could be causing this. I've tried zapping the PRAM, of course, as well as trashing preferences, although that doesn't make sense with the fresh system install anyway. Pulling the hard drive, network card, RAM, and video card from the IIcx and dropping them into a IIci (and the HD into an LC III) fails to replicate the problem; both Macs count time as normal.
Has anyone seen anything like this before? Any ideas on what it might be? At this point, I'm down to a logic board or component-level issue, but I don't have another IIcx to test that theory easily, not to mention would sort of rather it be something else.
Thanks for the help,
Cody
Cody
