About two weeks ago, someone nearby (1-1/2 hours, that's not too far for Vintage Mac parts is it?) had a IIcx and IIci board posted on Craig's list for $15, so I thought that might be better than spinning my wheels with this, so I picked them up, cleaned and re-capped the IIci board (I rescued the caps from the IIcx that was in the previous posts), carefully cut out an extra hole in the back of my cx case (for the onboard video - I had mixed feelings about that, but utility won out) and booted (with chime) into 7.5 on the IIci-x. The floppy needs to be refurbished, but otherwise it is in perfect shape. :beige:
The extra IIcx board that I picked up?
I booted it up to make sure that it worked as well and then I un-capped it. (I will re-cap it later, when I have time) ... for now I won't have to worry about the caps leaking.
One thing about that IIcx board, it was VERY easy to remove the caps, very little heat and very light twisting removed them. It was almost like the solder, holding the caps on, had dry-rotted, since they were almost falling off.
