System7
Banned
Well, I have decided that it is not impossible to fix the IIci. It is clear to me however, that it will need to be recapped, as the sound is gone. Luckily, there is no electrolyte damage.
The last time it was working, System 7 booted in 1 bit color, then crashed shortly thereafter.
I will post back later seeing if I can get it to boot at all!
Update:
I just noticed again that the Power Supply has some rust on it.....Not good. It was like that when I got it. The PCB looks ok however. Another daunting issue is that the CPU has bent pins. Yuck. Yet, I got it to boot! Amazing! It still needs tons of work to be fully functioning! If anyone could assist me with what I would need to replace the caps, I would appreciate it.
Update:
