I think some LCDs have a fuse on the LCD panel or something, and when it blows, the LCD displays a white screen.
Also, if the video cable is bad somehow, that could also explain it (in particular, one spot it is prone to breakage (this is also true of virtually any laptop) is where it winds through the display hinges). There's also a chance it could be a logic board fault, but I don't think so; those clamshell logic boards are usually quite resilient.
You can PM me if you're interested in my panel (it's a complete assembly, including hinges and cables, but it's from an Indigo clamshell; however, if you have any other color, the innards (cables, LCD panel) should be interchangeable.)
c
p.s. Also, it's a very bad idea to try plugging and unplugging internal cards and cables while the computer is powered on. You could fry things quite badly (I learned this the hard way, after damaging a $2,000 Macbook Pro after upgrading the display *while it was still powered on*; I wasn't very happy with the result [xx(] ).
