I Finally Opened My Color Classic!
Juliet Elysa
Hey y'all! Long time no speak! I've been in surgery fun land basically nonstop the last few years, but I'm finally at a point where I can (kinda) start lugging Macs around again! My first order of business tonight was to defuse the time bomb in my Color Classic, and thankfully, everything was in pristine condition, apart from needing a thorough dust removal. No leakage whatsoever! But there's a slight problem - the RAM was salvaged. Can anyone point me in the right direction for maxing it out, so I can keep troubleshooting?
Juliet Elysa
Turns out it's been a hot minute since I've been in the Mac realm, and I've forgotten a few basics, like soldered on RAM. There are signs of life from removing the battery! It won't get past this point, but hey - it's a lot better than I had several years ago! Is this a sign that a recap is needed, or something else?
Juliet Elysa
Thank you! That certainly seems more affordable than a Mystic upgrade, at least for the time being. My ultimate dream is to bring it roughly up to spec with my Performa 635CD, which looks like an LC 550 board + VGA mod.
bibilit
Probably won't work properly without new capos around and the Egret removed, cleaned and put back together (lot of contamination underside)
Juliet Elysa
Thanks! Do you know of anyone who'd be willing to help me with all that? I have zero soldering skill and really don't want to mess up my Holy Grail Mac.
The other thing to bear in mind with these is that the connections between the logic board and everything else are far less robust than they appear at this stage and work far less well. Make sure that the ground loops on the bottom of the logic board are actually making contact with the shielding on the bottom of the cage, and you may need to clean the edge connector.
nathall
Yeah, I’m not a fan of the grounding “system” in these. My CCII has issues after it sits for a while where those loops don’t want to make proper contact. I’m experimenting with shoving aluminum foil between the loops and the cage to increase the contact area, which seems to be working OK so far.
adespoton
When I still had my CC, I had to bend up the loops and use a bit of emery cloth on them to improve the contact at one point; worked great after that.
