Anonymous Freak
I'll check my 6.0.3 disks when I get home.
This second bit was part of a conversation discussing the programs and more modern Finder versions on a stock 512K using 64K roms:Use the "Mac Plus, 512Ke, 512K ..." Installer Script in the Utilities Folder on the System Tools disk to update an existing System Folder on the Hard Disk 20.
This might explain why the system can't handle newer finders.Apparently the new Finders jump directly in and out of the ROM at absolute locations, because during the errant call to GetMenu, Get Item is also called and on exit does a JSR (A0) to a location above the 64K ROM image -- apparently into a not existant 128K ROM routine.
Although I cannot confirm this, the new Finders also seem to be doing strange things to the trap dispatcher, as well as patching other ROM routines -- especially in the Resource Manager.
Well, my 6.0.3 floppies for the SE/30 do not have anything even vaguely called INIT Utility.Anyway, my search is still on for that elusive INIT Utility (which may or may not be a proper name). Is there no one among us who has the original 1988/1989 System 6.0.3 installer floppies that shipped with the Macintosh SE/30?
I do not follow you. I have been talking about getting the serial (non-SCSI) HD20 hard drive to work with an SE/30 computer. Toward that end, Apple's technical article mentions something they call an "INIT Utility" which supposedly allows copying the contents of the HD20 to the SE/30's hard drive. And there is an indication that this elusive utility/INIT was on a very early set of System 6.0.3 disks, hence my time in listing out the contents of the disk images currently available for download from Apple's website.I have a feeling that the best chance at this point is to hack the System file so that "Minimal" installation error doesn't appear and stop the boot process.
minus 50% of the content talking about a hd20 on a se/30? I was thinking the same thing as Henry as the post in question was on topic for the thread, just not whatever the heck you guys are onSystem software will work on a Mac 512k, giving special consideration to the ROM version.
Highest Version of System Software on Mac 512K & 512Ke
:?: :?:I do not follow you. I have been talking about getting the serial (non-SCSI) HD20 hard drive to work with an SE/30 computer.
What the hell are you going on about? Nothing in this thread, which I started, has anything to do with a hack. The question is and always has been, what's the highest system that can be run on a 512K or 512Ke (hacked or otherwise for that matter). And where do you get this "Mac + accessory" bit?the post seems like a simple thing, I have mac + accessory, what can I run on it? there is an entire section on this forum that is all about hacks, good luck and god speed!
Yep, the 64K and 128K ROMs are completely different code and require different ROM patches, and what probably is happening is that System 4.2 have deleted the 64K ROM patches from the System file. Similarly one reason System 7.6 won't run on a Mac older than the IIci is that Apple has again deleted the ROM patches for ROMs older than the 32-bit clean $067C ROMs from the System file.Suffice to to say, what works on a 512ke with 128k ROMs will necessarily work on a 512k with 64k ROMs, despite what a few websites (even highly respectable ones) report on the subject...
