Highest Version of System Software on Mac 512K & 512Ke
Mac128
This is going to be differnt for each machine, but what is the highest system version you have ever gotten to run on a Mac 512K or 512Ke?
Since the 512K requires loading the HD20 INIT into RAM, that is going to reduce the amount of RAM available for the larger systems. However, theoretically, the 512K and Ke should be able to run up to the same system versions.
It seems like I have run System 6.0.7 on a 512K, but that may have been the 512Ke (or I may be imagining things). I know for a fact I have run 6.0.5 on the 512Ke and have the HD20 running 6.0.3 at them moment.
I believe no one has ever successfully gotten the 6.0.8 System up on a 512K or 512Ke.
Please limit this to STOCK configurations and give the results of your experiences.
LCGuy
LC Doctor/Hot Rodder
My original Macintosh has been upgraded to full 512ke status, with 512k of RAM, and the newer ROMs that allow use of 800k floppy drives. I can confirm that I have definitely run System 6.08 on it. System 7, however, will not boot, as it complains about a lack of RAM.
Quadraman
From Mackido
System 4.1, Finder 5.5 (System Software 2.01)
Released: April 1987
Size: 422k | Download
Mac users had just a month to enjoy a nice 1 digit version number of their Mac OS. System 4.1 was released the following month newly adapted for AppleShare 1.1. AppleShare 1.1 was needed to network the newly released Mac II, and an updated version of the Mac OS was needed to accommodate it. Another update due to new technology was the way the Finder handled large capacity drives (namely those larger than 32 MB). This System also excluded a model, the Mac 512k, since you needed 1 MB of RAM to run it. This was the last time Apple did that for a while though, since they would not exclude models from running a version of the Mac OS for over ten years later, with the introduction of Mac OS 7.6.
So obviously someone's information is wrong because according to this from 4.1 onwards you need 1 meg and some people here say they have run later versions on 512ke machines.
JDW
System 6 will NOT run on the stock 512k with 64k ROMs. I've spent several hours in the past trying and failed. So Mac128's memory is recalling the 512ke, not the original 512k.
But I can say that I can run Finder 6.0 along with System 4.1 just fine on my 512k. And actually, Finder 6 is more of a pleasure to run too, versus older Finders. But again, I've not been able to run System 6 along with Finder 6. And if memory serves me correctly, I was not able to run any Finder newer than 6.0 either.
equill
The following was garnered from the mentioned sources a number of years ago. It reposes in a WriteNow file amongst my Classic Mode/OS 9.2.2 partition of this present iMac. The Forum's software makes a pig's ear of the tabular form of the data, but I'm sure that you can interpret it. 'Rec.' is to be read as the Mac model recommended. The column headers are Rec, System#, Finder#, 'System Software' #, File system, Released mo./year, Size (kB on Disk)
System Software for 128K (400kB), 512K (400kB) & 512Ke (400/800kB) Macs
Apple Macintosh 512K Specs http://www.everymac.com/systems/apple/mac_classic/stats/mac_512k.html
The Apple Museum / Home http://www.theapplemuseum.com/
Mac System 1.0 http://www.nd.edu/%7Ejvanderk/sysone/
MacKiDo/History/EarlyMacOS http://www.MacKiDo.com/History/EarlyMacOS.html
Old Macs Page http://www.sisp.net/~sulement/oldmacs.htm
Resources For The Older Macintosh http://www.trib.com/~dwood/oldmac.shtml
Welcome to Archaic Apples http://archaic-apples.shauny.de/index.php
Where to download Mac OS http://home.earthlink.net/~gamba2/syslist.html
  • — 1.0 1.0 — — 1/84 216
    — 1.1 1.1g 0.1 — 5/84 198
    128K 2.0 4.1 0.3/0.5 — 4/85 173
    — 3.0 5.1 0.7 MFS 1/86 211
    512K 3.1 5.2 1.0 MFS 2/86 497
    512K 3.2 5.3 1.1 MFS 6/86 312
    512Ke 3.3 5.4 2.0 HFS 1/87 333
    512Ke 4.0 5.4 2.01 HFS 3/87 260
    512Ke 4.1 5.5 2.01 HFS 4/87 422
    — 4.2 6.0 5.0 HFS 10/87 2188
    — 4.3 6.0 5.1 HFS 11/87 2197
My 512Ke was an 'e' when I received it, but it happily boots into 6.0.8 from floppy, its HD 20, and I am sure, its 40MB Quantum SCSI HDD when I get around to providing the Mac with a fan also. It has 2MB of RAM.
de
Mac128
I assume you mean you tried exhaustively by putting the HD 20 v.1.1 INIT in the System Folder as well?
I would trust your results over the Mac512K as I have rarely gotten much substantiative responses from gyounk, but these are his obervations with suggest it will run 6.0.8. http://www.mac512.com/macwebpages/qamac128.htm
I believe Charlieman has already discounted this and indeed confirms himself the 512K will not run System 6.0.x in his TCP/IP 512K article n which he also mentions the use of the HD20 INIT to overcome space limitations.
Apple's official position is that support for the HD 20 was dropped in System 6, presumably because no new Mac that required it was having the HD20 driver encoded into its ROM and therefore the corresponding system support was dropped as well. Oddly, the Macintosh Portable is listed as compatible in the Apple Guide to Hardware, which leads me to think all the SE-based 68000 Macs (including the Portable and Classic) retained the HD20 drivers in ROM. I found this link http://docs.info.apple.com/article.html?artnum=5712 which discusses an INIT I had not heard of before, required pre-System 6.0.4. It makes me wonder if the HD20 INIT is still required with System 6, whether the drivers are in ROM or not, as with the SE/30, which even with the HD20 INIT cannot reliably write to the drive. Perhaps all of these things are linked somehow?
However, if you tried it, then my memory is indeed flawed about the 512K!
JDW
I assume you mean you tried exhaustively by putting the HD 20 v.1.1 INIT in the System Folder as well? ...if you tried it, then my memory is indeed flawed about the 512K!
Correct. My tests included the HD20 Init -- testing with and without it. I tried it with my Hard Disk 20 too, but System 6 just won't work with my 64k ROMs.
Now I don't mean to suggest your memory is bad, but I would suggest that you put the 64k ROMs back into your 512k Mac and give it another test. It is highly likely you will discover what I have -- System 6 just won't work on the 512.
Nevertheless, my tests were "in the past" as well. So to ensure my memory is absolutely correct, I will retest within the next 48 hours, ensuring my test floppy is HFS formatted and has the HD20 INIT (as suggested by the web page you mention).
Mac128
Unless you just want to repeat past tests, I would wait until Charlieman weighs in. I believe Mac512's results are widely in question. It does seem to be asking a lot of a 512K to load 6.0.8 with or without an HD20 patch. Since I was not specifically testing for this, I may well have lost track of which board I had in the thing at the time, so I defer to more experienced heads.
JDW
Well, I will wait for Charlieman to offer his report within the next 48 hours then. :cool:
In the meantime, I would like to mention that to format a 400k floppy as HFS you must do the following:
1) Be running Finder 5.x or 6.x.
2) Format your 400k floppy but hold down the OPTION key when you click one-sided.
But the bottom of this web page makes it clear that you cannot boot off an HFS 400k floppy in the Mac 512k with 64k ROMs (because the ROMs don't support HFS). And since the computer cannot read the HFS 400k disk, putting the HD20 INIT on that disk in an attempt to make it boot won't work. It won't work because the computer needs to be able to understand the format of the disk in order to read it. If the computer cannot read the disk, then the HD20 INIT cannot be loaded. Hence, you cannot boot off HFS formatted 400k disks on the stock Mac512. If you try it and it works, then you have a 512ke (with the 128k ROMs).
Here is my detailed HFS/MFS post on this subject.
So you can see why the information posted here is clearly misleading at best. And despite what that site says, you will be hard pressed to fit System 6 and Finder 6 on a 400k floppy, even after trashing all the CPs, extensions and purging all fonts from the System file.
By the way, I just tested System 4.2 and Finder 6.0 on an 800k HFS floppy. I first booted off an MFS 400k disk that had the HD20 INIT. I then put my 800k floppy in my external 800k drive (the drive being directly connected to the Mac512). Then in the Finder, I double-clicked TeachText on the 800k floppy, which then switched the Systems from the 400k disk to the 800k disk. I could then eject the 400k disk and there was no need to reinsert it.
So if I redo my past tests on the 512, it would be in like manner. Namely, I would boot off an MFS 400k disk that had an older system/finder and the HD20 INIT. I would then need to see if I can put System/Finder 6.0.x on an HFS 800k disk and see if control will be handed over when I double-click an app on that disk. Of course, I could also try an MFS 800k disk too, but I've not found a way to format an 800k floppy as MFS on my Mac512k with 64k ROMs, without resorting to a hack. (You must verify whether or not the disk is HFS by booting with an HFS aware system or the HD20 init. Only then can you see the single pixel in the Finder window that shows if a disk is HFS formatted. If you see the pixel in the Finder window, then your disk is HFS 800k, not MFS 800k).
But booting off an HFS 400k disk with System/Finder 6.0.x is impossible on a Mac512 with 64k ROMs.
UPDATE: I just formatted an 800k MFS floppy by booting off the "magic" MFS 400k System 2.0 and Finder 4.1 disk (that also has the HD20 init). I then copied the contents of my S4.2/F6.0 800k HFS floppy to my MFS 800k disk. I then double-clicked TeachText on the MFS 800k disk which in turn switched System/Finder control of the computer to that disk. I was then able to use my MFS 800k disk just fine. I then rebooted and tried booting off the MFS 800k floppy (which also has the HD20 init installed in the System Folder). After a few seconds, I got to the Welcome to Macintosh screen but then a System Error ID=12 appeared. For whatever reason, I cannot boot off this 800k MFS disk with System 4.2. I also deleted off the HD20 INIT on the MFS 800K disk and then tried booting off it again. Nope. Same ID=12 System Bomb at boot time. So clearly, if I cannot get a known-good S4.2/F6.0 combination to boot of an MFS 800k disk, I don't see how I can get a System 6.0.x MFS 800k disk to boot!
Another Update (and possibly the "final word" on the subject):
I continued to test with various Systems and Finders in my MFS 800k floppy. I found that the "magic" S2.0 and F4.1 combination works great to boot my Mac512 off this MFS 800k floppy. I confirmed this works great with or without the HD20 INIT. Ditto for S4.1 and Finder 6.0, with or without the HD20 INIT. I then copied S4.2 over S4.1 after confirming that S4.1/F6.0 boots, leaving all other System files as is, but then the machine did not boot. So this would seem to show that S4.1 is the limit when booting off an MFS 800k floppy (at least, when in conjunction with Finder 6.0).
I then grabbed my 6.0.7 800k HFS disk and copied the System Folder to my MFS 800k floppy. After that, I double-clicked an app on my MFS 800k disk and the app launched just fine, and System level control of the computer was handed over too the 800k MFS floppy at that point. But when I quit the app and before I got back to the Finder, I got a System Bomb, ID=2.
I then proceeded to boot off my System 6.0.7 MFS 800k floppy. I got to the Welcome to Macintosh screen but then I got the error shown in this photo. Hmmm.
I then made an 800k HFS disk from a System 6.0.5 image that I had stored on my SE/30 -- "System Tools" (1 of the 4 System 6.0.5 install disks). I then put that disk into my Mac512's 800k external drive and proceeded to copy the System Folder onto my MFS 800k floppy. After the copy was completed, I launched an app on the MFS 800k disk and the app launched. But when quitting the app I got the ID=02 System Bomb. I then tried booting off the 6.0.5 MFS 800k floppy, but just as it got to the Welcome to Macintosh box, the box went blank and then started flickering like mad, at which point my Mac512 locked up. I then booted off my 400k S4.1/F6.0 floppy and then inserted the HFS 800k System Tools 6.0.5 disk. I double-clicked the installer app, but after a few seconds my Mac512 threw up another ID=02 System Bomb dialog.
Never willing to give up, I then copied my known-good copy of System 4.2 into the System Folder of my MFS 800k 6.0.5 disk (replacing System file 6.0.5). All other files in the System Folder were left untouched. I then added the HD20 INIT. This time, it booted to Welcome to Macintosh without the flickering freeze, but a second later (about when the Finder is to load), I got the ID=02 bomb dialog (with the Welcome to Macintosh box still visible in the background).
Am I beat? Heck no. I then tested S4.3/F6.0 with and without the HD20 INIT on my MFS 800k floppy. Nope. I get an ID=12 bomb at boot time. I then tried the same S4.3 and F5.5. Nope. Same ID=12 bomb. But my S4.3 didn't come from a disk image, so perhaps my copy of S4.3 is bad? No way for me to know without having a known good disk image, so if someone would be so kind as to help me out in that regard, I am happy to retest with S4.3.
Finished, you ask? Never! I then proceeded to put S4.2 and F6.1.8 onto an MFS 400k floppy, in a System Folder. No other files were on the disk. At boot time though, I got an ID=12 System Bomb.
And so, as you can see, the best I can do is S4.2 and F6.0 when running off an MFS 400k or MFS 800k floppy. If Charlieman can do better on a stock 512, I would certainly like to hear how it's done!
Thoughts?
Charlieman
Thanks for waiting, guys. And thanks for all of the testing, JDW.
I don't have my notes from my past experiments, but I do have the 400KB disks that I used for testing System 6 on a stock 512K. With judicious editing, I was able to cut down System 6 so that it would fit on a 400KB MFS disk with the HD20 INIT. I used System 6.0.2 because it was the smallest stable version. Like JDW, I found that the Mac booted initially and then fell over.
For an explanation, this oldish thread gives some possible clues Mac Startup Sequence. My thoughts are that the Mac just boots without any checking of the disk format. In the case of a Mac with 64KB ROMs, the Mac bombs when booting System 6 because System 6 code assumes an HFS disk.
Perhaps there might be further clues in Inside Mac or contemporary TechNotes.
Mac128
Here's another clue, relating to the use of HD20: http://docs.info.apple.com/article.html?artnum=4437
Now this refers to the 512Ke, which I know for a fact works with 6.0.3 off a HD20. There also appear to be other errors in the tech note (i.e. calling the 512Ke a Plus which can most certainly run 6.0.3 and the HD20), so perhaps they meant a 512K. However, if os it confirms 6.0.1 on it. If they did mean a 512Ke, then the Plus would suffer from the exact same issues as I believe they are architecturally identical with the exception of the SCSI bus and extra RAM mux.
Also, this may indicate differences which might have been dropped in System 6 as the 64K ROMs were no longer relevant: http://docs.info.apple.com/article.html?artnum=1778
If these are real limitations for the 512K, 512Ke & Plus, then there may be something to what Mac512 says and what JDW's test demonstrated ...
...that the installer must configure a minimal system for the Mac Plus, from which any system reductions must be made. I have certainly run into situations where a particular system would not work if copied onto a Plus, but would if it were installed specifically for the Plus. This is the same reason the "Magic Disk" works – certain resources are copied into the system file which are not necessarily present in minimal startup copies not customized for specific hardware, like startup disks and tools.
Given that the 512K is already saddled with the HD20 INIT and a 400K startup-handoff to the external System, perhaps System 6 must be treated the same way as an accepted limitation of its use, i.e as Charlieman suggests System 6 requires an HFS boot disk, looking into real directories not present on an MFS volume.
Of course there are practical considerations here as well ... even with the stock 512K running System 6.0.8, with extra RAM consigned to the RAM based HFS & drivers, how much useful software can actually be run on it?
JDW
Well, I think that official Apple article says it all: System 6 is not supposed to be compatible even with the 512ke! It just so happens, per Mac128, that some flavors of System 6 do work on the 512ke.
Nevertheless, that same article also admits that 6.0.1 might work on the 512ke. So if someone wants to PM me with a working disk image of 6.0.1, I will give it a test. And even if you don't "want" to give me a copy, do it anyway for the sake of science! :beige: (Ditto for a System File 4.3 disk image that I request in my post above.)
Scott Baret
Apple's database has a history of occasionally being wrong. They list the SE/30 as being discontinued in 1990, for example (it was made through October 1991, their own sales literature can confirm that).
I think what they mean to say is that they don't recommend running 6.0.x on a 512Ke. You can do it, just don't expect to run some high-end program with it. Something like MacPaint runs fine. I've tried both 6.0.5 and 6.0.8 on the 512Ke and both work. (So did 4.1).
Most books will back up this claim. I remember the Jim Heid/Peter Norton book from the late 1980s mentioning that a 512Ke can run System 6. I think Que's book on upgrading and repairing Macs also does. (My copy actually is completely duct-taped together since I've used it so much over the 13 years I've had it).
Don't believe everything you read on other sites either. So many have gotten the SE/30 date wrong it's not even funny.
JDW
Scott, I'd love to hear your tests on a stock 512k with 64k ROMs! I am not surprised to hear that 6 will run on a 512ke. My interest is in the 64k ROM Mac512.
Also, Scott, if you have System 6.0.1, would you might PMing me. I want to test that.
Scott Baret
If I had a 64K ROM 512K I'd test it.
I don't have 6.0.1...I have disks that are labeled as 6.0.1 but unfortunately it appears Apple stuck 6.0.2 on there instead. They came with a Plus.
JDW
A kind member of this site emailed me a disk image of System 6.0.1 today. Many thanks for your kindness in furthering science! :)
Another great thing about the System 6.0.1 disk image sent to me is that the entire System Folder is under 400k. It was a snap to copy it to a freshly formatted MFS 400k floppy. I then tried to boot my Mac512 with it. However, I got the same error I reported in my post above, shown in this photo. It gets to the Welcome to Macintosh screen and then 3 seconds later it throws up the "Minimum" Installer Script error.
Does this mean it's simply missing a System Enabler? Or is it a meaningless error dialog that basically means "System 6 won't run on your 64k ROM Mac512"? If it is simply in need of an enabler, then how does one go about hacking that in via ResEdit?
NOTE: Technically speaking, System Enablers originated with System 7 and therefore do not apply to old compact Macs up through and including the plus. See Apple Tech articles: here & here.
Thanks.
Mac128
JDW this goes back to what I was saying earlier. When I look at my 6.0.8 installer and select minimum system for Mac Plus it indicates that the system won't be able to run on any other Mac. Whether that means it adds something or doesn't include something is unknown. Sadly I don't have 6.0.1 install disks to check. But I can certainly check the differences In 6.0.8. If the minimal install for all Macs (which the version from disk tools you are almost certainly using, is) includes aspects of System 6 which are looking for hardware the 512K doesn't have or are incompatible with the HD20 INIT, then that might also account for the error you are getting.
JDW
Very true, Mac128. However, when I spoke of a "system enabler" in my previous post above, I was hinting at a hack similar to what we have for the SE/30 (i.e., changing a 003 to a 005 in ResEdit) that allows running of 7.6.1 and 8.1 on SE/30 hardware. True, you also need a IIsi or IIfx ROM in conjunction with the System file hack, but perhaps such a hardware mod would NOT be needed on a Mac512 in order to run 6.0.x? This is a question I therefore put forth to the community, especially you 68k programmers out there. Surely you would know what it would take, if even possible at all, to make System 6.0.x run on a stock 512 with 64k ROMs. But in the end, if there's no hope to get System 6 to run on the original 512, so be it. At least we tried! [:)] ]'>
