Hi. I came into the possession of a 68040 based CPU upgrade similar to a Quaddoubler. Could somebody help me find out for which Quadra/Centris model it was designed? The "missing pin" is in the upper left corner, near the C24 mark.
I believe this is a Newer Technology product for the Quadra 700 with a 68040 running at 50MHz. "Newer Technology (A division of Spectrum Engineering)" appeared in some early '90s publications. Note the 700-B model number on the label.
Thank you all! With those informations, I found out that this item is actually for Quadras and Centris 610. I'm a bit surprised : cooling is only made with a heatsink and a fan. I thought that 50mhz versions of this kind of accelerator required peltier junctions or other aggressive cooling methods.
a 40 mhz rated 040 wont get to warm at 50 mhm. im pushing a 25 out of a centris at 40 mhz on a spare board to test and fails wihen warm with just heat sink, with fan have yet to get a lock up.
