Oh, I'm confused now. What do you mean by a clean ROM?I didn't mention 24 bit addressing.
Yup, which allows you to run 32bit, and address more than the 8MB limit with 24bit addressing, the default (32bit extensions like MODE32 aside) for a stock SE/30.The OP put in a Rominator II in the SE/30.
Ah, I'm sorry. I misread your post. I thought you said the ROMinator wasn't needed with 16MB. My badThe OP put in a Rominator II in the SE/30.
Yeah, just because you can doesn't mean you should. Computers are more fun when you run a fast and responsive OS on them. 6.0.8 and 7.1 are perfect for an SE/30 without a processor upgrade.Yea I tried to do Mac OS 8.1 in mine but it was slow even with 128MBs memory. so IMO the best gain is yea it allows 32 bit mode which then allows you to increase the RAM to a descent level for Mac OS 7.1
Same, I use MODE32 on mine. But ROMinators are vastly more expensive for us brits. Perhaps it would be a better option if shipping / taxes didn't double the price.MODE32+Force32 is my preference instead of a Rominator II at all. The real 'benefit' of the custom ROM is to be able to boot from a ROM disk.
Yup, you can. Almost makes sense on a IIci for compatibility, but dog slow even at 25MHz.Pretty sure you can run/trick an SE/30 to do 7.6.1 and 8.0/8.1 without a Rominator II as well...
Oh, there is a load. I used to intentionally run 7.6.1 on a second disk on my IIci as a kid. It was usually a lie though, enforced by installers and their OS version checks. Many things could be back ported all the way to 7.1.3.I can't think of much software you'll run into that requires Mac OS 7.6.1 or higher. Maybe Mac OS 7.5 or Higher.
It wasn't a few, times have changed. In those times you got whatever version of a program you got, from friends or cover disks or wherever. If it ran, great, if it didn't, you didn't have that program.Agreed but any attempt to run those few programs on an SE/30 would be dissatisfying IMO.
