mattbee
Can anyone suggest a next step here?
I've got an SE/30 which boots from hard drive to "Welcome to Macintosh". But the desktop doesn't come up. The prompt disappears (leaving the white box) and the pointer freezes. If I hold shift, sometimes it will confirm that extensions are disabled, and come up with a "The system disk may be damaged" etc. message, encouraging me to repair the install with a floppy.
So after replacing its floppy drive, I wrote a System 7.0.1 floppy but it won't boot from it. It spins the floppy, reads a little bit, then ejects it and boots from the hard drive again.
I've tried writing with rawwrite on Windows via a USB floppy. I'd also tried converting the .dsk image to Kryoflux's raw files, then writing through my Kryoflux setup. I tried with a couple of different 1.44M floppies. It still rejects the disc.
Am I making any obvious errors here? Next I'm going to try again writing the system disk from a Power Macintosh G3, but was hoping I could reliably manipulate floppy images from Windows.
Thanks in advance.
Thanks in advance.
