From the archives: An article on the Fall '93 '040 Macs...
LCGuy
LC Doctor/Hot Rodder
So i was having a look around the net today, and found something rather neat: Dale Adams on the Fall '93 '040 Macs
For those who don't feel like clicking the link:
Today Apple introduced a number of new desktop machines: the Quadra 605, Quadra 610, Quadra 650, LC 475, and several Performa variations of the LC 475. As I'm sure many of you are curious about these machines, I thought I'd post some information on them and try to partially stave off the list of questions that invariably follows a new product intro.
First, the Q610 and Q650:
The Q610 and Q650 are simply faster versions of their (now discontinued) Centris counterparts. The Q610 is a 25 MHz version of the C610, and the Q650 is a 33 MHz version of the C650. This speed increase is the major change. Most things remain the same, including: I/O support, maximum memory expansion, number of slots, and video support.
There are a few minor differences. The required speed for VRAM for the Q610 has increased from 100 ns (for the C610) to 80 ns. Note that the required speed for DRAM for the Q650 has remained at 80 ns, while the Q800 uses 60 ns DRAM. In addition, there are now more configurations of these machines which use the 'full' 68040 (i.e., with floating point hardware) rather than the 68LC040. All versions of the Q650 come with a 68040. There are versions of the Q610 that come with a 68040, unlike the C610 where all configurations used a 68LC040. A heatsink is not required for a 25 MHz 68040 in the Q610.
From a performance standpoint, the Q610 is about the same speed as the old C650, and the Q650 is about the same speed as the Q800. The Q610 is marginally slower than the C650 due to the latter's use of interleaved memory (a difference of only a few percent). The Q650 is just a tad (one 'tad' being equal to about 3-5 percent) slower than the Q800 due to the use of 80 ns DRAM in the Q650 instead of the faster 60 ns DRAM used by the Q800.
That's about it, really. The best way to look at these products is simply as faster versions of their old Centris counterparts.
Now, the Q605 and LC475:
The Quadra 605 and LC475 are newly designed machines, although they've been derived from the earlier member of the Quadra/Centris family. It's probably more appropriate to look at these two as a single machine, since the only real differences between them are cosmetic ones. A good way to visualize these machines is as a Q610 in a smaller box (in the case of the LC475 the enclosure is identical to that of the LC III), with only a single DRAM SIMM, no onboard ethernet, and and LC III style expansion slot instead of a Quadra PDS.
Processor
All configurations of these machines come with a 25 MHz 68LC040. Although there are no versions offered with a 68040, the processor is socketed and can be removed to allow the use of a 68040. A heat sink is not required if the processor is upgraded to a 68040. Performance of these machines is very similar to a Quadra 610 with a 68LC040.
Memory
There are 4 MB of DRAM soldered to the logic board. A single 72-pin DRAM SIMM socket allows memory expansion to 36 MB (using a 32 MB SIMM). SIMM sizes of 1, 2, 4, 8, 16, and 32 MB are accommodated. Expansion DRAM must be 80 ns or faster. Only a single SIMM socket is offered due to the lack of available space on the logic board. (Remember, it's only an LC-sized board.)
I/O
The I/O complement of the Q605 and LC475 is basically identical to a Q610 with the exception of no onboard ethernet. One minor difference in the audio input circuitry is that these machines require the newer PlainTalk microphone instead of the original Apple microphone used by previous non-AV '040 Macs.
Video
The onboard video capabilities of these machines are identical to the Q610 (and the Q650, Q800, etc...). All monitors supported by the Q610 are supported by the Q605 and LC 475, including displays up to a resolution of 1152x870 (i.e., Apple's 21 inch monitor). Video memory can be expanded to a maximum of 1 MB, and with this amount of VRAM these machines support 16 bits/pixel up to resolutions of 832x624, and 8 bits/pixel at resolutions above that.
Video memory expansion is handled somewhat differently than on the Q610, however. There is no VRAM soldered to the logic board - all video memory is on SIMMs. The base amount of VRAM is 512 KB, in the form of two 256 KB (128K x 16) 80 ns VRAM SIMMs. In order to expand VRAM to 1 MB, the original SIMMs must be removed and replaced with two 512 KB (256K x 16) 80 ns VRAM SIMMs. Unfortunately, there simply wasn't room on the logic board for either more SIMM sockets or to solder down the original 512 KB of VRAM.
One other key difference in the onboard video is the lack of sync on the green video signal. Like the recently introduced AV Macs, the Q605 and LC475 do not provide a composite sync signal superimposed on the green video signal.
Expansion Slots
The Q605 and LC475 have a single LC-III style expansion slot. It is compatible with a large number of the expansion cards currently offered for the LC family. Note that this is not a processor direct slot on these machines, although it is on earlier LC models. Since the LC slot was defined as a 68020/68030 PDS, and these new machines have a 68040 processor with a different processor bus, there is a bus adapter necessary to convert 68040 bus signals to those required by the LC PDS definition. Because of this, the LC slot does not actually sit directly on the 68040 processor's bus, and hence is not a true PDS.
Basically, what this means to the end user is that not all LC expansion cards will work (or even make sense, for that matter) in a Q605 or LC475. In particular, cards such as accelerators, cache cards, and FPU cards (i.e., 68882's) will not work. However, the majority of I/O related expansion cards (e.g., video, networking, etc.) should work just fine.
Enclosure
The LC475 comes in the same enclosure as the LC III (with a different nameplate, of course) and uses the same power supply. It therefore has the same options for internal drives as that machine. The enclosure for the Q605 is cosmetically different, but holds the same size logic board, same power supply, and has the same internal disk drive options as the LC enclosure. It's my understanding that there will be an upgrade to the LC475 from the LC II and LC III.
- Dale Adams
Dated November 16th, 1993 too, so this would have been one of the very first documents on the public WWW. :) I actually remember when these machines were new, so its a fairly nostalgic experience reading this and remembering how exciting these machines were. :) I was only 8 years old, and a total Mac n00b, but I still remember how much I wanted a Quadra. :p
Edit - Nearly 24 hours later I just realised I made a typo when adding the link :I
Scott Baret
An excellent find!!! I remember when the 475 was announced, I had originally thought it was going to be called the LC IV. Being an LC (original) owner at the time I was excited to hear about this new machine.
I was a year younger than LCGuy at the time and while I would have taken a Quadra (especially a 950) my dream machine was a PowerBook 180c (which I finally got over fifteen years later).
LCGuy
Yeah...I remember reading back in the day that a heatsink is not required...but still, considering the age of these machines, I think its advisable. My LC475 has a full '040 in it, and I've put a heatsink on it.
Temetka
Great article.
Any '040 I have owned has had a heatsink added to it by me. Touching the chip and feeling how hot is makes me seriously considering adding at least passive cooling to it.
shred
Nice find.
The reviewer missed one difference between the LC475 and Quadra 605: the Quadra 605 came with a PDS ethernet card fitted (at least in Australia, anyway). The only difference between the two motherboards was the position of a single jumper, so that "About this Macintosh" correctly identified the machine as an LC or a Quadra.
