Faulty Radius PC 24X - looking for repair tips
croissantking
I've acquired this non-working Radius PrecisionColor 24X (quite a nice card as I understand), which I'm interested in repairing.
Running it in a Macintosh IIci, the current symptoms are that there's no output, and it's not listed in TattleTech either – it's invisible to the system. I guess that if the card is not even detected then the Mac is not able to read the declaration ROM. But... the previous owner @mg.man says that he has already tried swapping in another ROM chip from a known good card, so it's unlikely to be that.
I would be interested in flashing a V2.0 ROM to an EEPROM chip just to double check, if anyone has a dump they could share with me.
Are there other common faults with these cards that could cause this behavior?
As the pics show, the card looks immaculate.
I'd start by checking for lose pins on the ASICs, or if the ROM socket needs cleaning / is damaged.
Have you checked for bent Nubus pins?
mg.man shared the V2 ROM. Confirmed working by me.
I'd check these two. Hard to see, but they could be solder bridges.
They're nice cards, I have the 24xk but have a big ROM set up so I can switch between the 24x and 24AC ROMs.
olePigeon
I never tried using the 24AC ROM. Is there any advantage to using the Apple one over the Radius?
Performance is equivalent. Truth is I prefer the Apple driver, it integrates with the Monitors control panel.
It offers fewer options... But let's be honest I never fiddle with the settings anyway.
croissantking
No luck so far. I’ve checked:
- all Nubus pins are straight
- ROM socket is clean
- no solder bridges on the ASICs
Poke all the pins with a pin or scalpel blade gently to see if any aren't stuck down :)
You just want to see if any move.
Unknown_K
I don't see any fuses, or 0 Ohm resisters used as cheap fuses.
Pop the ROM out and see if any connectors are mangled (since it has been removed at least once). That ROM socket is from the thru-hole era so every connector in the socket has a pin on the back of the card to check for continuity.
If the card is not detected (and the ROM and ROM socket are good) you have either something shorted or something open. With no fuses and nothing visibly getting warm or blown (are the main chips getting warm when installed in a turned-on machine?), I would get a meter and start poking around the capacitors checking to see if there is any voltage present. Find a section with no voltage and then start looking for a component that is open (blown).
