quinterro
I finally have my Lombard up and running (mostly). However it will overheat if left alone since the cooling fan never comes on. Currently I'm using one of those PC slot fans to draw air through the openings in the side of the case, but a more elegant solution would be greatly appreciated.
The TemperatureMonitor program only shows 1 sensor and that is located in the hard drive.
