While this looks to be the likely cause, if it doesn't end up fixing the issue, I'll quickly note that I have two SE/30s. One works great with my Ethernet card. The other unit won't boot (black screen, no chime when the card is installed). It's the logic board as I have moved the logic board that won't boot with the Ethernet card installed to other unit's chassis/analog board and same issue.
