Even more strange , EveilCapitalist, is that that second floppy port would work! I did this experiment years ago by attaching a second floppy to that unit and knocking out the faceplate - taking the space where the HD would normally go. I also left the HDD connected. So my hacked LC had a floppy hanging out of the side, and I was able to copy floppy to floppy with it, and even run games two floppies at a time to avoid the need to swap disks all of the time. Kind of an impractical build, but a successful proof of concept nonetheless. Now, to find that unit among my boxes of goodies.....Strangely enough, it looks like there's a second floppy port on the motherboard despite there being no case opening for another disk drive.
Thats not strange, thats by design. His post was referring to the fact that the case lacked a second floppy opening even though the mobo had dual connectors. Implies the LC was not originally meant to have two floppies. Or it means this is in fact a later case design for single manual-inject setup with an earlier motherboard.Even more strange , EveilCapitalist, is that that second floppy port would work! I did this experiment years ago by attaching a second floppy to that unit and knocking out the faceplate - taking the space where the HD would normally go. I also left the HDD connected. So my hacked LC had a floppy hanging out of the side, and I was able to copy floppy to floppy with it, and even run games two floppies at a time to avoid the need to swap disks all of the time. Kind of an impractical build, but a successful proof of concept nonetheless. Now, to find that unit among my boxes of goodies.....
This is not a definitive photo comparison between proto and production, as I think there is one other proto board in between these. I have two LC proto's that have the reset button (where the production does not), but the config of VRAM and RAM and VSLU of what is the production board pictured on the right. Likely there were several board revisions prior to release. Just filling in the gapsYep, this is an LC prototype
I have had these things for years. Mine came from the warehouse clear out from Apple Canada. I worked there in the late 90's. They were clearing out all kinds of stuff, and I decided to grab it all (for a fair lot price) in hopes of one day making a museum. Life happened, so the museum did not. Now I have the need to sell it all off as it is taking up so much room - so there are these and a few other goodies that I didn't even know that I had really, until now when I really get a good look at them. Both power supplies are shot on these things, but using my working one from my LCIII, one unit work flawlessly, booting off an 80MB drive into SSW 6.01, I think it is. The other, the one with the confidential markings on the chips, boots to a flashing ? and the 40SC HD does not boot. Also, too a strange whistling sound like old radio frequency changing. The battery is totally corroded away too. Might be something up as a result of that too. Will keep plugging along on these and the rest of my collection.That is amazing, thanks for sharing.
How did you find your two protos?
