Franklinstein
I haven't seen much on here about these delightful examples of portable computing (at least, not much positive), so I thought I'd have a go at it.
I've pulled the keyboard apart on my FrankenDuo (Duo 210/250/280 parts) because it really didn't work anymore. It's very strange. Has anybody else tried this?
The keys are really easy to get on and off, just pull up on 'em (and push them back down to replace). Then, the rubbery membrane lifts off. On the underside of the rubber, you'll notice the black circles - bits of electricized rubber, which bridge the crescent-shaped contacts of the two clear plastic sheets underneath it.
Since the traces on the plastic sheets are little more than exposed metal (it's very much like defroster traces), I was thinking how it would be best to go about improving the contact between the rubber of the top membrane and the contacts on the electrode sheets. I was kind of thinking very fine sandpaper might work, get rid of whatever oxidation or whatever else is impeding my circuits without damaging the keyboard too much.
Not quite sure how to approach the rubber membrane, though. I'm thinking just soaking it in warm water might get rid of any accumulated impurities well enough.
Has anybody else attempted to restore a Duo's keyboard to a usable state?
