Dimensions of threaded inserts?
j2theLj
Hi, I broke off a screw in one of the threaded inserts of the screen hinge of my PowerBook 160. I need to buy some new threaded brass inserts but I’m unsure of the correct dimensions, my instruments aren’t precise enough to correctly measure it. Does anyone know for sure?
3lectr1cPPC
Oh nuts. I remember hearing the measurement somewhere but I forget where that was. May have been in a This Does Not Compute video, I’ll have a look.
I did the same thing to my PowerBook 150 but I’m really screwed there as it was after gluing down the 3D printed hinge fix part I installed. I’m going to need a new back case.
j2theLj
Thanks, it would be great to know. I see they sell different dimensions on AliExpress but there are many different kinds with only slight variations. I guess I should be getting some quality calipers if no one knows... Maybe you can melt out the insert with the broken screw and rework it with epoxy somehow?
beachycove
Can you just extract another screw, toddle along to a suitable hardware store to find a nut to fit it, read the specs, and then do the ordering?
3lectr1cPPC
Yeah I couldn’t find the dimensions in either of the places I thought they may be. I saw them somewhere though…
