DiimoCache in SE/30 really unstable when cache is turned on
Knez
Hi!
My SE/30 runs just fine with my DiiMoCache as long as the cache is disabled using the preferences panel. As soon as I turn it on it starts pushing out random "type 1" errors and random freezes. When the cache is disabled all is fine (but much, much slower).
I'm thinking that it might be something wrong with my DiiMo.
Specs are:
  • Totally recapped SE/30 (analog board, motherboard, PSU)
  • 128mb RAM
  • MacCon soldered with a straight connector (done by Bolle)
  • Bolle's "topper" adapter on top of the MacCon
  • DiiMoCache card connected to the Topper adapter
  • SCSI2SD v5.1
It's a wonderful machine, but I'm getting a bit frustrated with it now.
Knez
Just tried with a fresh install of 7.1 with nothing more than the DiiMo control panel added. Freezes seconds after I turn on the cache :(
Byrd
I'd be stripping it down to the basics - just the card (no topper), less RAM (put back in some 1MB sticks), stock ROM - any more luck that way?
amedeo_68k
iirc the DayStar powercache also had issues turning on caches when running on SE/30, I'm not aware of DiMo, however the DayStar one works fine if used with @Bolle twin adapter that includes a built in ethernet. You could try, however every board have its own story, probably Bolle could give you better info.
Bolle
Can't remember from the top of my head... which revision of the adapter did I send you @Knez?
I had a IIci DiiMO here at some point to test it in my adapters but I think that wasn't yours but from someone else. It did run fine including when caches were turned on with the ethernet/adapter combo card (which is basically the same as a MacCon stacked with the newest revision of the Topper adapter)
Knez
I’m quite worried that I damaged it somehow when the PSU in my other SE/30 blew. This DiiMO was in that SE/30 when it happened and has experienced some kind of high current situation. MacCon seems to work like it should though.
I’m worried that the MacCon, Topper or DiiMO have been damaged. But as I mentioned, everything is rock solid as long as I keep the cache turned off.
Will try messing with the RAM later today and see if that makes any difference.
Knez
@Knez how the high current happened ?
@amedeo_68k PSU blew but I didn't notice until it fried my motherboard (screen got garbled, sound got messed up etc). Didn't measure the voltage until it was too late. Bought another SE/30 and moved the MacCon, Topper and DiiMOCache over from the broken one. DiiMO worked flawlessly in the old one until the PSU acted up.
Knez
Took out all the cards from the SE/30 and reseated them firmly. All seems to be well now. Managed to get through MacBench and 3 hours of tinkering and playing games last night without any trouble.
Interesting comparison btw.
Stock machine vs DiiMO with cache turned off vs DiiMO with cache turned on.
Thanks for the input, guys :)
