Dimitris
Hi,
I'm new to this forum as a signed user, but I've read a lot of forum's postings due to my interest in SE/30
I would like to hear your opinion to a problem that I'm facing with my SE/30 and Daystar Turbo 040.
First let me tell you the upgrades that my SE/30 has.
I have replace the standard hdd with an Apples 2GB scsi.
I put 8 x 16MB simms so total ram is 128MB
I replace the power supply with one from Stratos
The first card in the PDS slot is an Asante Ethernet.
The second card is a Daystar Dualport iisi, which with a paper clip i have connect pin 11 & 13 (using a tape) of the PDS-slot for the Daystar Accelarators.
In the PDS-slot for the Daystar Accelarators i have connect a Daystar Powercache P33 running at 50Mhz
To connect the second card to Asante i used a right angle 120-pin connector
The third card is a Radius Pivot PDS Card with 1MB video ram.
To connect the third card to Dualport, I used a right angle 120-pin connector.
I bought from ebay a Daystar Turbo 040, so to replace the Powercache P33.
But when i connect the Turbo040 and powering up the machine, horizontal black and white lines appear in the screen.
I have tried with no other cards and no HDD, only motherboard, the Dualport and the Turbo040 but with same results.
I have to mention that when i first bought the SE/30 sometimes produces these horizontal black and white lines when powering up. but after a while this phenomena stop.
In addition to this, the sound never worked. I can't hear anything from SE/30.
I have cleaned the motherboard with alcohol mixture 95% that i bought from pharmacy, using a tooth brush.
Many thanks in advance for any replies.
