Converting Acard AEC-7722 to AEC-7726
jcarron2
New member
Edit for the above post: (unable to edit original one? )
I have tried running this on Win10, and Win7. My scsi card is only working on Win7, so that is why I am using older python in the above example (3.8).
On a Win10, with Python 3.11, I run into the same issue...
C:\Python\Python311>python.exe SCSIDEHacker.py
File "C:\Python\Python311\SCSIDEHacker.py", line 25
print 'SCSIDE was started'
SyntaxError: Missing parentheses in call to 'print'. Did you mean print(...)?
And need to modify the code with the parentheses... After doing that I run into the same error as in above post #60.
Jonathan
jcarron2
New member
Learned more about python than I ever wanted to, managed to get a little bit further, but ran into I think a policy issue in Python.
Had a look at an example of python hooking (below link), but tbh it is probably too much for me to just jump into having near nil experience with python :
(https://github.com/srw/windows-api-hooking-in-python-with-deviare-sample)
Nektra forums (http://forum.nektra.com/forum/) appear to be down ...
Did anyone have any luck making this work? Right now I'm stuck with the pythoncom error: Python error invoking COM method.
Here is what I have done so far:
-Download, extract Deviare binary from github, extract Deviare.2.8.3.zip and regsvr32 DeviareCOM64.dll, regsvr32 DeviareCOM.dll
-Download Python python-2.7.17, and pip for 2.7 (https://bootstrap.pypa.io/pip/2.7/get-pip.py)
-Install Python 2.7.17, and execute python -m get-pip.py
-change dir to python directory/scripts, and run pip2.7.exe install pywin32
Unzip SCSIDEHacker.py and you will need to edit it.
Update the below lines, spacing is apparently important or you will get an error message about "inconsistent TAB USE" - WOW... python=painful
1. Update path for
sSCSIDEExe = 'C:\Program Files\SCSIDE Firmware Utility\SCSIDE.exe'
2. Goto line # 188 - print("Cannot launch {}" % (scside))
Code:
  File "SCSIDEHacker.py", line 188, in main
TypeError: not all arguments converted during string formatting
There seems to be an issue with printing string "CAnnot launch" and type scside.
Within my few hours of learning a bit about python, there doesn't seem to be a easy way to convert the scside spyManager.CreateProcess result to a string, so I just removed that part and printed the text only.
From an elevated command prompt, I was able to launch the python script after the above modifications, however I now see some messages related to "pythoncom error: Python error invoking COM method."
Code:
EG: 03:37:12.806000 (PRE) DeviceIoControl(0x00000294) IOCTL_SCSI_GET_ADDRESS
lpInBuffer (0 bytes):
03:37:12.806000 (POST) DeviceIoControl(0x00000294) IOCTL_SCSI_GET_ADDRESS
lpOutBuffer (8 bytes):
0000:  08 00 00 00 02 00 01 00                          ........
03:37:12.821000 (PRE) DeviceIoControl(0x00000294) IOCTL_SCSI_PASS_THROUGH_DIRECT
lpInBuffer (80 bytes):
0000:  2c 00 00 00 00 00 06 0e 01 5d 80 00 38 00 00 00  ,........]..8...
0010:  ff ff 00 00 64 f7 18 00 30 00 00 00 12 00 00 00  ....d...0.......
0020:  38 00 00 00 00 00 00 00 00 00 00 00 00 00 7c 00  8.............|.
0030:  00 00 00 00 c8 5d 80 00 fc f7 18 00 27 e7 66 77  .....]......'.fw
0040:  c8 5d 80 00 00 00 00 00 14 f8 18 00 06 71 63 76  .]...........qcv
Traceback (most recent call last):
  File "C:\Python\Python27\lib\site-packages\win32com\server\policy.py", line 27
7, in _Invoke_
    return self._invoke_(dispid, lcid, wFlags, args)
  File "C:\Python\Python27\lib\site-packages\win32com\server\policy.py", line 28
2, in _invoke_
    return S_OK, -1, self._invokeex_(dispid, lcid, wFlags, args, None, None)
  File "C:\Python\Python27\lib\site-packages\win32com\server\policy.py", line 64
9, in _invokeex_
    return DesignatedWrapPolicy._invokeex_( self, dispid, lcid, wFlags, args, kw
Args, serviceProvider)
  File "C:\Python\Python27\lib\site-packages\win32com\server\policy.py", line 58
5, in _invokeex_
    return func(*args)
  File "SCSIDEHacker-mod.py", line 37, in OnFunctionCalled
    self.DeviceIoControl(nktHook, nktHookCallInfo, nktProcess)
  File "SCSIDEHacker-mod.py", line 78, in DeviceIoControl
    sptd = self.DumpSPTD(lpInBuffer)
  File "SCSIDEHacker-mod.py", line 107, in DumpSPTD
    raise Exception("Invalid SCSI_PASS_THROUGH_DIRECT length")
Exception: Invalid SCSI_PASS_THROUGH_DIRECT length
03:37:12.868000 (POST) DeviceIoControl(0x00000294) IOCTL_SCSI_PASS_THROUGH_DIREC
T
lpOutBuffer (44 bytes):
0000:  2c 00 00 00 00 00 06 00 01 5d 80 00 24 00 00 00  ,........]..$...
0020:  38 00 00 00 00 00 00 00 00 00 00 00              8...........
So made a little progress, however, I am really not sure what is stopping Python from invoking COM method. It seems this rabbit hole may go pretty deep at the moment.. Probably something related to security or some hole that was plugged long ago by a KB patch....
At this point I'm thinking it's going to be faster to unsolder the TSOP chip and buy some PLCC flash chips and mess about.. sigh.
Hopefully someone out there has some idears!
Jonathan
Decker
New member
Do you have anyinfo on how to get this working?
I have downloaded the binary Deviare2, extracted it and tried starting the CSharpConsole COMHookingBasis [Edit I don't know what im doing here] , but when I run the python script I get the following (after installing pywin32com)
Note 2 - modified python script as Python reported all the "print statements weren't valid -
Code:
C:\Python\Python38-32>python.exe SCSIDEHacker.py
  File "SCSIDEHacker.py", line 25
SyntaxError: Missing parentheses in call to 'print'. Did you mean print('SCSIDE
was started')?
Changed lines like
to
print ('SCSIDE was started')
C:\Python\Python38-32>python.exe SCSIDEHacker-mod.py
File "C:\Python\Python38-32\lib\site-packages\win32com\client\dynamic.py", lin
e 86, in _GetGoodDispatch
IDispatch = pythoncom.connect(IDispatch)
pywintypes.com_error: (-2147221005, 'Invalid class string', None, None)
During handling of the above exception, another exception occurred:
File "SCSIDEHacker-mod.py", line 198, in <module>
main()
File "SCSIDEHacker-mod.py", line 181, in main
spyManager = win32com.client.DispatchWithEvents('DeviareCOM.NktSpyMgr', NktS
pyMgrEvents)
File "C:\Python\Python38-32\lib\site-packages\win32com\client\__init__.py", li
ne 312, in DispatchWithEvents
disp = Dispatch(clsid)
ne 117, in Dispatch
dispatch, userName = dynamic._GetGoodDispatchAndUserName(dispatch, userName,
clsctx)
e 106, in _GetGoodDispatchAndUserName
return (_GetGoodDispatch(IDispatch, clsctx), userName)
e 88, in _GetGoodDispatch
IDispatch = pythoncom.CoCreateInstance(
thanks for any info
Jonathan
Lesson: Do not waste time on a vague post. Didn't even specify what OLD version of Python they were using. Two or three more lines of info would have saved people a lot of time. So it's just a useless approach. Take the flash off and put the PLCC socket on. Please don't waste more time on this. :)
Caveat: FYI: You cannot talk to a SCSI interface using the PASS THROUGH DIRECT "hack" junk method unless it's 16 or 32 bit mode. If you try over an 8 bit SCSI bus it will fail no matter what.
Abe
New member
Has anybody figured out how to reflash a 7722 so it works with IDE hard drives and/or CompactFlash-to-IDE adapters withOUT desoldering or [re-]soldering anything?
Given a working procedure and all the needed files, I could do it on Mac [“real” Mac OS, i.e. pre-X], Mac OS X [either PowerPC 32-bit or Intel either 32 or 64-bit], GNU/Linux on a PC [I still have Debian/PowerPC on one or two 32-bit machines, if I can still get it working], or even [blech, holds nose] Microsoft Windows or DOS-for-a-PC [e.g. MS-DOS].
My soldering/desoldering skills are close to non-existent.
I bought a 7722 from a little-to-no-information eBay seller who didn`t bother to post in the listing the fact that the device is ATAPI-only as shipped from the factory, probably didn`t know that himself, and probably wouldn`t have understood it if I had told him in technical terms such as “ATAPI-only” rather than idiot-friendly terminology such as “this adapter is only for CD and DVD drives”. IIRC [this was at least several months ago], I played around with a Mac-based reflashing utility, I think one that was provided by ACard — maybe one for Mac OS 8 or 9 — and did _not_ succeed. My 7722 has been sitting in its cardboard box doing nothing ever _since_.
TheMrKocour
You can spoof the device identification to SCSIDE.exe to trick it into burning the AEC-7726H firmware to an AEC-7722. I have successfully tested this with a AEC-7722 modified in this way, attached to an IDE hard disk. See attached Python script, you'll also need the NktSpyMgr from https://github.com/nektra/Deviare2 to do the required hooking.
It worked! I flashed ACARED 7720 REV 3.0 using this script. It took quite a bit of lab work to check everything out. The working combination was Windows 7 Pro 64x, python 2.7.6 (32b), pywin32-222, and lasted Deviare. I also edited the script and selected SCSI ID and type of ACARD.
Now i need to work on REV 1.8 (i got error when flashing)
mars
New member
I flashed a rev 3 7722 with the u3bg173q firmware and it definitely works with a CF card and adapter...about 50% of the time. The other 50% it times out when reading the first block on the CF card on boot. Here is everything I've established so far:
  • I'm trying to use the acard in a IIci.
  • The acard is jumpered for single-ended mode.
  • I am using the corrected 16-bit to 8-bit SCSI adapter from the linked eevblog forum thread. I had the board made from the files in the poster's github and assembled it.
  • I noticed that the acard seemingly doesn't have built in SCSI termination (SCSIProbe says that the bus is unterminated when the acard is connected [internally] as the only device on the SCSI bus) so I made a ribbon cable for it with an extra connector so that I could attach a passive terminator to the end, after the connection to the acard.
  • On boot of the machine, when the acard isn't working, the booting process appears to be stalled. Meaning, the machine sits for a very long time on the grey background before finally giving up and displaying the question mark no startup disk icon. While the machine is waiting, the activity LED on the CF card adapter is solidly on, rather than blinking rapidly like it would while reading normally.
  • Whether it works or not seems to be entirely based on powering on. Half of the time after the acard and the CF card are powered on it works without issue for as long as it's powered on, meaning it even continues to work after a soft reboot. However, you shut down completely and cold boot, and it times out on reading the first block of the CF card. Power off again, and magically works again. I would say it's about 50/50 whether it works or doesn't work after powering on.
  • I have confirmed that it isn't the SCSI bus on my IIci because I tested the acard in another mac (mid 90s power mac) and with a BlueSCSI in initiator mode, and the exact same behavior happens.
  • I have confirmed that it isn't the power supply in my IIci because I have tried powering the acard and the CF card off of another power supply and the exact same behavior happens.
    • This test allowed me to confirm that whether it works or not is determined when powering on. I was able to leave the IIci running, with the acard in a state where it wasn't working, power-cycle the acard and the CF card separately and confirm that I was now able to mount the drive via SCSIProbe.
  • I have confirmed that it isn't the CF card because I've tried multiple CF cards I have that work fine in other machines such as my Turbo IDE in my IIgs and the exact same behavior happens.
  • I have confirmed that it isn't the CF card adapter because I've tried the adapter that came with my Turbo IDE that definitely works and the exact same behavior happens.
    • I also tried one of those Hyperdisk disk-on-modules, eliminating the CF card adapter completely, but the exact same behavior happens.
  • I know that it's timing out on the SCSI READ command by looking at BlueSCSI initiator mode debug logs, and also using the utility Sedit to issue the READ command directly and looking at the sense data after the command times out.
  • Weirdly, even when the acard is in the state where READ command times out, the INQUIRY command seemingly works just fine because SCSIProbe is still able to detect the acard and display the vendor info from the CF card. It's just that then when you try to mount the drive, SCSIProbe sits for a long time while the activity LED on the CF card is solidly lit and then eventually it times out and SCSIProbe usually crashes and quits.
    • You can re-open SCSIProbe after the mounting times out and INQUIRY again just fine, or even try to mount again (which is 100% guaranteed to fail until you power-cycle the acard).
INQUIRY still working is the most confusing behavior and is the main thing keeping me from just assuming that my acard is bad. The microcontroller on it is clearly still functioning and responding to commands and is even able to send multiple bytes on the SCSI bus. I'd say it was something wrong with the CF card, but like I said, I tried multiple CF cards and a hyperdisk and they all had the same issue. Also, it's weird that it would be able to read the metadata from the CF card needed for the INQUIRY command, but it can't read any of the actual data blocks? Also, why would power-cycling be enough to make the READ command work again? In all, a very weird set of circumstances that have stumped me, anyone else experience anything like this with their acard?
