rabindranath72
Hi all,
has anyone tried it? I have a Mac SE/30 16Mb RAM running A/UX 2.0. I downloaded the (patched) gcc-2.5.7 from a jagubox mirror, which according to the README should compile on A/UX 2.0(.1). The architecture is recognised, the configure process seems to work, but then compilation fails at the first file: cccp.c
First I get a warning about a table being full, so no optimisations are possible. Then the whole process halts when "as" is called, and I get a core dump.
Any help would be appreciated.
Failing that, is there another version of gcc out there which works on A/UX 2.0?
Thanks,
Antonio
Thanks,
Antonio
