@jimbojones Are you saying that a MC68882 labeled as 40 MHz works with 16? Interesting.
16 MHz doesn't seem plausible at all. Anything made after 1990 is going to be of a mask that'll run at 40 MHz minimum, so who would want or sell 16 MHz FPUs?
I bought and installed a FPU advertised as 16 MHz in 1992 (roughly ~ 100 US$ then) into my original LC (very similar to a CC). I don't know about other manufacturers at that time but speaking about Macs the majority (if not all?) that could be retrofitted with a FPU had 16 to 25 MHz clock speed. Actually I would be happy if my 68882 would work with 20 MHz, I could transplant it into a IIsi.
About speed gains: If memory serves me, there are relatively few ones.
My main goal then was to make a
relatively cheap 68020 machine more Mac II-compatible. I mostly succeeded since many Mac II-applications demanded a FPU, and were happy when they found one on the LC.
Some scientific software came both in FPU- and SANE-version (SANE is the set of software calls or functions - never sure what is what - for floating point operations). The FPU versions turned out to be about twice as fast as the SANE-versions. This was still a bit of disappointment for me, since a FPU call should be many multiple times faster than going the long way through a SANE call. And I remember how much faster a 8087 equipped IBM PC was compared to a plain one with a similar application type.
Many other software showed no speed gain at all, probably - I guess - as floating point arithmetic is usually avoided as much as possible because it is so slow. I'm, quite sure JPG compression is solely integer based.
