superjer2000
@Bolle You seemed to have solved this in an earlier thread - I couldn't quite tell what fixed it though... (and it was only 10 years ago so I'm sure it's still top of mind!)
I recently recapped the analog board in one of my Color Classics. When I started it back up I noticed the colours were off - after a bit of investigation, it seems that green is not working.
I hadn't powered the system up for literally years before so I can't say definitively if the system worked before the recap (from my notes it did back in 2018 apparently.)
There are two adjustment drive pots at the back of the analog board (blue and green). The blue drive pot does change the intensity of the blue but the green drive pot doesn't change anything. When I play with the convergence, I can see the red and blue but there isn't any green. There three other adjustment pots (red background, green background and blue background). When I crank the green pot up the screen background does go greens so the gun is working.
1. I reheated/added solder to all of the connections at the back of the video neck board. No change.
2. I played around with the green drive pot while taking measurements with my multimeter. It seems to behave the exact same as the blue pot so I think the pot itself is OK. I can test for good continuity on the A/B from the green drive pot to the same components as to the blue drive pot. There seems to be a lot of overlap between the green and blue drive pots with regards to what traces are connected to what - I was hoping that the logic would be more discrete so it'd be easier to test directly from the video connector on the A/B to the video neck board, going through the drive pot, but no such luck.
3. I checked for continuity between what I think are the R/G/B signals coming off the video chip on the mother board and the edge connector on the motherboard.
4. I checked for continuity between the edge connector and the video plug on the analog board (under the metal cover). It seems good although there was one connection that didn't seem to beep right away). Not sure if that was the cable from the edge connector, the solder joints, or me trying to balance the analog board and multimeter to test.
5. I reheated/added solder to the connections from the analog board that go to the video neck board. No change.
What I'm really hoping for is some thoughts as to what connectors might be responsible for sending the green gun information. There aren't any analog board schematics as far as I can tell. There are two bunches of wires going from the A/B to the video neck board. There are some colored wires (pink/yellow/red/black/blue/orange) that are soldered directly into the A/B and there are a bundle of three white wires that are plugged into a harness near the adjustment pots. I'm assuming it's the three white wires that are providing the R/G/B video signal but I'm hoping to get confirmation from that so I can spend more time poking around in that area...
Thanks!
Thanks!
